> First peak behind passenger seat, Rear window question
Rhodes71/914
post Nov 30 2004, 01:26 AM
Glacier
Decided to pull the pass seat and see what it looked like under there. Not to bad actually, every time I read a rust post I got scared.
Here's a pic of the back window behind the pass side back pad. Is there supposed to be something holding the window in besides the sealing tape that is hangin down.
iamchappy
post Nov 30 2004, 07:37 AM
It all happens so fast!
The black tape on the bottom of the window is stock, thats the way mine came from the factory.
Rhodes71/914   First peak behind passenger seat   Nov 30 2004, 01:26 AM
Rhodes71/914   Also is that grey covering on the firewall stock, ...   Nov 30 2004, 01:30 AM
tesserra   Yes there is. After you fix and seal the window y...   Nov 30 2004, 01:31 AM
McMark   Gray pad is stock, "sealing tape" is not. Use 3M ...   Nov 30 2004, 01:35 AM
scott thacher   that tape you see is an attempt to stop the leak h...   Nov 30 2004, 01:37 AM
SpecialK   Yep, clean the channel and reseal the rear window....   Nov 30 2004, 01:41 AM
SpecialK   After looking at your window pic again, it's o...   Nov 30 2004, 01:48 AM
iamchappy   The black tape on the bottom of the window is stoc...   Nov 30 2004, 07:37 AM
boxstr   Since he didn't say anything about the window ...   Nov 30 2004, 09:20 AM
rhodyguy   after you scratch the hell out the frame area remo...   Nov 30 2004, 09:26 AM
Rhodes71/914   Yes the window is loose, was rattling quite a bit ...   Nov 30 2004, 11:32 AM
Quebecer   Welcome to the club ! :evilgrin: :evilgrin: ...   Nov 30 2004, 02:22 PM
SirAndy   also, do the "crunch test" on the floor behind the...   Nov 30 2004, 03:09 PM
SpecialK     Nov 30 2004, 05:48 PM
boxstr   Good eye Kevin. CCLIN20/20   Nov 30 2004, 10:22 PM
SpecialK     Dec 1 2004, 01:36 AM
Rhodes71/914   Ok guys thanks for the support. Hopefully I will h...   Dec 1 2004, 10:12 AM
mskala   ...   Dec 2 2004, 08:50 AM
Eric_Shea   That rust on your firewall is from the hell hole p...   Dec 2 2004, 10:08 AM
Rhodes71/914
  Dec 2 2004, 11:15 AM
- Lo-Fi Version Time is now: 31st October 2024 - 08:25 PM
