914-6 wiper motor question |
mb911 |
Jun 2 2019, 10:32 AM
914 Guru Group: Members Posts: 7,161 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
As I work on my -6 clone I was wondering what most use for the wiper motor? I swear someone mentioned using a 944 motor??
ClayPerrine |
Jun 8 2019, 05:57 AM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Just buy a 911 wiper motor setup. Set the 911 wiper rack next to the 914. You will see that the tubes that pass the arms through the cowl are longer on a 911. So take the 911 wiper rack apart and shorten the tubes to the same length as the 914 rack. Then put the shafts and arms from the 914 rack into the 911 rack. Use the 911 motor. Or, just get a 964 wiper rack assembly. It will bolt right into the holes on the 914, and it sits much closer to the cowl on the underside. You will have to make a support for the motor though. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:56 AM |
