North Coast Jim |
Member ![]() ![]() Group: Members Posts: 339 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region ![]() ![]() |
Looking to add an Air Fuel guage to help finalize my new carb install. Adding a bung for the O2 sensor it seems like I should remove the heat exchangers to help the fabricator add the bung. Is this needed or can it be done while in the car ?? Where to actually add the bung, any suggestions or pics.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I've been doing some testing, but it was on a 914 2.0 DTM T4 into a bug conversion with a CSP 4/1 SS header into a SS corvette muffler, in/out same side.
A huge area of concern is on each side of the header and muffler flange, the muffler side I see a 150+F drop in temperature. Enough of temp drop that the sensor doesn't have enough heat to be optimal. I was very surprised to see how big of a temp drop it was each side of the exhaust flange. Temps were taken at the end of a 30 minute test run at 3000rpm with a laser gun. Wish I had a stock or SSI /4 to see what the temp in a stock muffler or triad is... For a six I'd put the bung on the header after the collector, but then this becomes a two meter system. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,190 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
For a six I'd put the bung on the header after the collector, but then this becomes a two meter system. I only put one sensor in the header on the passenger side. Probably not ideal but it seems to be working just fine. (IMG:style_emoticons/default/shades.gif) |
Maltese Falcon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,041 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
For a six I'd put the bung on the header after the collector, but then this becomes a two meter system. I only put one sensor in the header on the passenger side. Probably not ideal but it seems to be working just fine. (IMG:style_emoticons/default/shades.gif) That's a perfect spot, with the bung facing upwards at 12'oclock. On the 9146 header collector...you are sampling 3 ports at once= good. At the rear of a T4 heat exchanger, it will be good to capture 2 ports...so have your fabricator/ welder look for that spot Maybe just at where the 2 tubes join up into the muffler. Otherwise you will only be sampling 1 exhaust port = not optimal, but will work |
Lo-Fi Version | Time is now: 18th April 2025 - 04:11 PM |
