VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,722 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
As I get closer to Dyno Day for my 914 (July 22), I have a theory about some of my drivability issues.
This car has modern EFI, not carbs or Djet/Ljet. It’s running MS2 through a Microsquirt controller. The car is clearly very rich. It bogs heavily coming off idle, to the point that it will sometime stall out if you don't dance the accelerator pedal just right at a stop sign or a traffic light. Last oil change I could also smell gas in the oil. And while Bob Hill ( @saigon71 )was driving my car the other night I occasionally saw puffs coming out of the muffler on overrun. Kinda cool, in a way, but not great.... lol. I hooked up my trusty ancient tuning laptop and opened up the AFR table while looking at the AFR meter. Where the table is showing ~13, the gauge was swinging ~15.5, especially just off idle, when the car got hot. So my theory is that the ECU is reacting to a false LEAN condition and dumping huge amount of gas into an already rich environment. So, my possibilities are:
@Eric_Shea @Mark_Henry @chrisfoley Thoughts? Zach |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,981 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Are you sure the system is running closed loop when it's showing lean?
VaccaRabite |
Are you sure the system is running closed loop when it's showing lean? No. And if the ECU isn't set to use the AFR to add or pull fuel my theory is blown. I should have checked that last night while I had the tuning laptop up. I've been working on the assumption that its. Zach |
Lo-Fi Version | Time is now: 26th April 2025 - 01:55 AM |
