brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,645 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Hello everyone... and thanks in advance.
I'm cross posting this, so if it reads kinda "weird" that is why. I'm trying to do a wiring harness from scratch on a race car. Its a 1967S 2.0/6 motor.... first question: Would this be an internal or external voltage regulator on the alternator? (I'm guessing its an external, so I probably need to wire a regulator in somewhere) second question: I'm replacing the tiny alternator warning light with a LARGE warning light.... I've seen this on other cars but they usually had a full wiring loom intact. a)Do I need to pay attention to the wattage of the warning light bulb to get the circuit to excite? b)should I wire a resistor in line to meet this need of a particular wattage and then wire my warning light seperate? c) if b is true, then how would I wire the light seperate? d) help...? that should about cover all my questions for the next 24 hours or so... Most of the circuits (ie: fuel pump, switched ignition power, etc.) have made simple sense... but I'm struggling a bit with the alternator so thanks a ton fellas!!!! brant |
brant |
Ooops...
not enough details huh.. Its a -6 If I throw the fan belt, the cooling fan stops working and I cook the heads. so I want some kind of alternator warning to tell me when the belt is off. I have no factory wiring left what so ever. No regulator, no dash, no original guages to tap into... I'm making up a full harness from scratch so that it will be lighter than stock. Is there a way to forget about the alternator circut and wire in some other type of switch to alert me to when the belt is off? I've got the warning lights I want already, but am trying to figure how to wire them brant |
Lo-Fi Version | Time is now: 1st July 2024 - 01:21 AM |
