914 Suspension motion ratios, Comparing notes |
groot |
Nov 27 2004, 09:53 AM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
I measured my front and rear motion ratios yesterday and wanted to compare notes with any that have done the same.
For the rear suspension I took ~20 data points and did a best fit analysis to come up with 1.00 to 1.00 damper travel to wheel travel with strong statistical correlation. My front geometry is a bit different than a standard 914, so the motion ratio should be different, too. I measure ~10 points and found 0.83 damper travel to wheel travel, again with strong statistical correlation. I'm about to order my rear shocks and this is one of the bits of data they need to build the shocks. |
redshift |
Nov 30 2004, 05:42 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
First off, all you guys have lost your lids.. (IMG:style_emoticons/default/laugh.gif)
I never imagined the roll center on a lower car being below 0.. this is very interesting. That explains some of the twitchy stuff you get at medium speeds with a very low street car. I need to go back.. and read it again... keep talking... M |
Lo-Fi Version | Time is now: 25th June 2024 - 10:14 PM |
