sketchc13 |
Newbie ![]() Group: Members Posts: 13 Joined: 7-February 11 From: NorCal Member No.: 12,675 Region Association: Northern California ![]() |
I’m looking to figure out what size the oil drain plug in the case is. e.g. M12 x 1.25
The PO helicoiled the case for the drain plug on my engine. I don’t know if the bolt in there is the original bolt that the helicoil was sized for or if they just put a helicoil in what was left of the original threads and put a smaller bolt in. As it is right now, the helicoil was done pretty poorly so something has to change. I saw another thread discussing options for timeserts, helicoils, or pipe plugs too, so just want to figure out what nominal should be and go from there. Thankfully the engine is apart so all options are on the table. |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
My recollection is that the original threads were 14 x 1.5 but I don't know that for sure.
I had a bus case with the same issue and I recut the thread for a 911/944 drain plug and liked how it worked out. The 911/944 drain plug is something like 18mm diameter. I had the engine apart at the time some chips and shavings were not a problem. Jim |
Lo-Fi Version | Time is now: 26th June 2024 - 12:00 AM |
