JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,578 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
What is it about 914s in particular that incites their owners to want to ‘improve them’, ‘build what the factory should have built’, etc., or just make them something they are not because it is convenient? Talking in part about body mods, but also ‘performance’ mods.
The best quality builds – esthetically or technically - are cool to see/experience and we all appreciate them, but it’s the human element that sometimes gets us shaking our heads. Maybe it’s the fantasy/vision some have, that they either have not thought through their ‘solution’ completely or perhaps they do not have the skills/time/money to fulfill once they begin that path downhill. Body mods – have we seen all possibilities by now? If you want a Por-Tessa or a cab-91X wide body or a front engine 914 – just buy a real one. Wait, none of those mutants are factory-produced cars. Performance mods – You want power? A stock 2.0L is not that much different than a 1.8L powerwise, so if you want real power just find a significantly bigger lump. Making a 2.0L from a 1.7L, and doing it correctly involves lots of changes, decreases originality and will still not allow you to lay rubber down in your ‘hood. Swaps – You have a flywheel from a Pantera on the shelf and remarkably it fits perfectly…should you use it? How about putting on the injection from a VW GTI, you only need to fab a few custom bits to mount it, and you need to find someone to reflash the ECU and use custom built injectors. Can you make a 2.0L banana muffler fit a 1.8L? You are Ok that no reputable shop will ever want to touch your 914 again with those mods (they don’t now anyway) because you plan to keep it forever. Because you can and because you want to. But we all know you won’t keep it forever – someday someone else will own it or it will be found as a failed dream rotting in a field somewhere. We are just temporary caretakers in this world. So this post is not a complaint about poor decision making, but is intended an as encouragement to fully think through mods, and carefully consider the realities of available time/money/effort needed to fulfill a vision. Make wise decisions and help save the 914, they are becoming an endangered species. Attached image(s) ![]() |
oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,329 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
I have kept or returned my 76 2.0 to close to stock as possible, no fender flares, wings or engine mods for me. That said, here’s the modification list that I post at car shows of all the little changes that I have made over 20 years that help me to enjoy driving it more. Things like the armrest center console, or moving the brake pedal over slightly to allow more room for my size 13 feet. The smaller Momo steering wheel is on an eccentric hub that raises it an inch so I have more legroom. The Blazecut fire protection system adds a little extra fire safety, and the third strobe brake light also adds some safety. Here’s the list:
1976 Porsche 914 Modifications Engine, Original 2.0 Liter, Fuel Injected - K&N air filter - Monza exhaust system - Crane electronic ignition system - Nology HotWires sparkplug wires Exterior - Empi rims - Hella dual horns - Porsche door stripes - Cloth lined front trunk - Engine lid restraint cable - Black Widow security alarm - LED front signal and running lights - Front fender parking lights removed - Optima battery external charger port - Targa bar mounted strobe LED third brake light - Porsche front bumper plate with LED illumination - BlazeCut automatic engine fire suppression system - Porsche rear reflector lens with LED running and brake illumination Interior - HD Mirror Camera - Porsche dash light - Rennline short shift kit - LED dash gauge lighting - “Heater On” dash indicator light - Solenoid activated rear trunk release - Momo steering wheel with eccentric lift spacer - Tartan cloth seats with driver’s side cushion thigh lift - Fog lights rewired for use as Daytime Running Lights - Blaupunkt six speaker stereo system with electric antenna - Brake pedal repositioned leftward to increase gas pedal foot room - Raised center console armrest with cupholder and fire extinguisher |
Lo-Fi Version | Time is now: 27th June 2024 - 07:56 PM |
