brainf18 |
Newbie ![]() Group: Members Posts: 19 Joined: 12-May 19 From: Louisville KY Member No.: 23,116 Region Association: None ![]() |
I was looking for a set of 6.5x15 steel wheels for track days. I wanted to run 205/15's all the way around. Wasn't able to find any low cost "off the shelf" solutions for an unmodified 4x130 bold pattern. So I settled on 5.5in wheels and ordered a set from Sierra Madre Classics. ($59 each)
When the wheels arrived, they looks suspiciously larger than 5.5 inchs. So I put a tape measure on them and to my surprise they were just a few mils under 6.5 inches wide. I test mounted this morning and the backspacing and offset were spot on. Problem solved. Though others might like to know... https://sierramadrecollection.com/Steel-Whe...1-2-p19583.html [/url] ![]() ![]() ![]() ![]() |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Wheel, OEM VW, Steel, Silver, 15 in. x 6 in., 4 x 130mm Bolt Circle, 5 in. Backspace, Each $62
https://www.summitracing.com/parts/usw-131-5630/overview/ |
80’s old school |
Member ![]() ![]() Group: Members Posts: 79 Joined: 26-March 19 From: California Member No.: 22,994 Region Association: Southern California ![]() |
Wheel, OEM VW, Steel, Silver, 15 in. x 6 in., 4 x 130mm Bolt Circle, 5 in. Backspace, Each $62 https://www.summitracing.com/parts/usw-131-5630/overview/ Cool. If this size is for real. This will be the ticket for me. Thanks. I will check into this further. I noticed my local Americas Tire carries this. |
Lo-Fi Version | Time is now: 25th June 2024 - 05:04 PM |
