mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,957 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
So my 2.4 is fresh -0 miles with only start up minutes on it. I rebuilt the carbs and powdercoated the steel air filter assembly and replated all the hardware and am really thinking of selling the setup in favor of running a 3.2 fuel injection setup on likely with an aftermarket ecu as I don't think the dme will work well with my setup..
Any thoughts or experience with what I am proposing? Now note that I have done this on a 3.0 before with good success just no experience with a higher compression low displacement solex cam engine.. Thoughts? ![]() |
roblav1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region ![]() |
Same sort of boat I'm in...trying to figure out either PMO 46 or engine management system. 3.0 liter, 9.5 CR, same cams as Mark.
Not sure what Ben was referring to with carb changes depending on temperature. I never had a problem... in cold, just press accelerator pedal a few more times to get it going. Then it'll run bailky for 5 minutes until warm. BTW, most of my experience is with small displacement Solex and S cam engines with Webers. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:50 AM |
