mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,957 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
So my 2.4 is fresh -0 miles with only start up minutes on it. I rebuilt the carbs and powdercoated the steel air filter assembly and replated all the hardware and am really thinking of selling the setup in favor of running a 3.2 fuel injection setup on likely with an aftermarket ecu as I don't think the dme will work well with my setup..
Any thoughts or experience with what I am proposing? Now note that I have done this on a 3.0 before with good success just no experience with a higher compression low displacement solex cam engine.. Thoughts? ![]() |
mb911 |
@tdskip they are about 1300-1600 depending on what you get . that's right from sdsefi.com
As to temp changes and carbs I can tell you that rejetting in our neck of the woods is very common as we have temp and humidity changes that swing from 100 degrees in summer to 35 degrees in fall and spring and don't talk about winter.. Efi compensates for this. |
Lo-Fi Version | Time is now: 25th June 2024 - 01:12 AM |
