mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,957 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
So my 2.4 is fresh -0 miles with only start up minutes on it. I rebuilt the carbs and powdercoated the steel air filter assembly and replated all the hardware and am really thinking of selling the setup in favor of running a 3.2 fuel injection setup on likely with an aftermarket ecu as I don't think the dme will work well with my setup..
Any thoughts or experience with what I am proposing? Now note that I have done this on a 3.0 before with good success just no experience with a higher compression low displacement solex cam engine.. Thoughts? ![]() |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Triple Speed Triumphs are the hot ticket @MB911 we will be in touch, I have almost everything you will need except the air cleaners, I was going to take a metal 911 unit and make it work on the adapter plates for the Air filters.
I have a set of PMOs for my -6 and well that is about as good as it will gets running carbs. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:38 AM |
