> First peak behind passenger seat, Rear window question
Rhodes71/914
post Nov 30 2004, 01:26 AM
Glacier
Decided to pull the pass seat and see what it looked like under there. Not to bad actually, every time I read a rust post I got scared.
Here's a pic of the back window behind the pass side back pad. Is there supposed to be something holding the window in besides the sealing tape that is hangin down.
Rhodes71/914
post Dec 1 2004, 10:12 AM
Glacier
Ok guys thanks for the support. Hopefully I will have some time tonight to pull off that pad, looks like it is glued on there pretty good. Of course I will post pics when I get in there.
Rhodes71/914   First peak behind passenger seat   Nov 30 2004, 01:26 AM
Rhodes71/914   Also is that grey covering on the firewall stock, ...   Nov 30 2004, 01:30 AM
tesserra   Yes there is. After you fix and seal the window y...   Nov 30 2004, 01:31 AM
McMark   Gray pad is stock, "sealing tape" is not. Use 3M ...   Nov 30 2004, 01:35 AM
scott thacher   that tape you see is an attempt to stop the leak h...   Nov 30 2004, 01:37 AM
SpecialK   Yep, clean the channel and reseal the rear window....   Nov 30 2004, 01:41 AM
SpecialK   After looking at your window pic again, it's o...   Nov 30 2004, 01:48 AM
iamchappy   The black tape on the bottom of the window is stoc...   Nov 30 2004, 07:37 AM
boxstr   Since he didn't say anything about the window ...   Nov 30 2004, 09:20 AM
rhodyguy   after you scratch the hell out the frame area remo...   Nov 30 2004, 09:26 AM
Rhodes71/914   Yes the window is loose, was rattling quite a bit ...   Nov 30 2004, 11:32 AM
Quebecer   Welcome to the club ! :evilgrin: :evilgrin: ...   Nov 30 2004, 02:22 PM
SirAndy   also, do the "crunch test" on the floor behind the...   Nov 30 2004, 03:09 PM
SpecialK     Nov 30 2004, 05:48 PM
boxstr   Good eye Kevin. CCLIN20/20   Nov 30 2004, 10:22 PM
SpecialK     Dec 1 2004, 01:36 AM
Rhodes71/914   Ok guys thanks for the support. Hopefully I will h...   Dec 1 2004, 10:12 AM
mskala   ...   Dec 2 2004, 08:50 AM
Eric_Shea   That rust on your firewall is from the hell hole p...   Dec 2 2004, 10:08 AM
Rhodes71/914
  Dec 2 2004, 11:15 AM
- Lo-Fi Version Time is now: 31st October 2024 - 08:25 PM
