ride height, is there a measurement |
bernbomb914 |
Nov 29 2004, 12:10 AM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
My car is slamed to the ground. It has 21mm t bars in the front and 140 lb spgs in the rear. I would like it to ride a bit smother and want to know if there is a measurement that I can use that will let it handle but not ride like a cement mixer?
Bernie Attached image(s) |
Mueller |
Dec 1 2004, 10:51 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
yep, like others said, get rid of the KYB's, you might want to put back in stock torsion bars and go with a stiffer swaybar or not...just make sure you have "a" swaybar that is adjustable (endlinks wise as well)
how are your suspension bushings? if they are binding, they will act like springs and cause too much resistance you'll love the yellow Konis (IMG:style_emoticons/default/pray.gif) |
Lo-Fi Version | Time is now: 28th September 2024 - 05:53 PM |
