Alternator/Voltage Regulator issue, Alternator light is on until rpm's increase |
PDXMike |
Jul 26 2019, 09:41 AM
Slowly Learning Group: Members Posts: 111 Joined: 20-December 10 From: Portland, OR Member No.: 12,501 Region Association: Pacific Northwest |
My alternator light stays on after I start the car. It was dim, and it would go off (and stay off) as soon as I got the RPMs up over 1000 or so. I did eventually find a faulty connection between the battery and the Voltage Regulator, which I thought would solve my problem. Instead, I now have a similar condition except that the charge light is on full bright (not just dim, like before) until I blip the rev's up a bit. It will still go off and then stay off for the rest of the time the car is running.
With the car running at about 1000rpm I am getting 14V at the battery. Pulling the VR and shorting D+ to Df results in 16-17V at the battery, so I am assuming my alternator is good. I thought there was something going on with the VR not applying enough voltage to the field at start-up, so I ordered a replacement. They new Voltage Regulator is an AC/Delco part, not the OEM. I have exactly the same issue with the new Voltage Regulator. Any ideas? Thanks! Mike |
Rand |
Jul 26 2019, 02:50 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I haven't heard of bootstrapping a 914. It is basic electrical circuits, not a computer. My gen light only came on once, and a quick wiggle of the VR fixed it which pointed me to cleaning the terminals. Never happened again. If you only could be so lucky, but point being, if the light light's on, something IS wrong. No way in hell should you write it off as normal. It comes on for a reason which usually indicates a dirty electrical connection. If you start introducing LED lights and such, it gets more tricky because of resistance changes.
Lo-Fi Version | Time is now: 26th June 2024 - 12:29 AM |
