How alternator light works, a more detailed description |
Tom |
May 3 2014, 01:30 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
After reading many accounts of how this circuit works, I felt compelled to investigate further as I did not understand how two positives would cause a light to operate. They won't. One must be somewhat negative to complete the circuit. Internet searches turned up the same basic explanation, still was not buying it. I think it was being oversimplified.
This is how I think the alt light works: When the key is on and engine not running, there is 12 volts + at the alt light power side coming from the fused side of fuse #9. The other side goes to a junction on the relay board with D+. With the key to off and a meter connected between D+ and ground at the relay board, the reading is 12 ohms. As soon as the key is turned to on, the reading jumps to 12.5 meg ohms and the light comes on. If the wire for D+ to the alt is removed, the reading stays the same and the light stays on. Removing the VR caused the reading to jump to infinity and the light goes out. For the light to work, there has to be power to one side of the light and some resistance reading to ground for the other. Looking at the wiring diagram, one can follow the blue wire to the junction at the relay board at D+, then up thru the VR to a set of relay contacts, then down thru a ( resistor ?, not sure) and then down to the DF connection and on to the rotor where the current will produce a magnetic field. After the rotor, it goes to ground. When the alt spins enough RPM's, a voltage is produced and fed back to the VR, causing the relay to open and removes the ground path for the alt light. I could be entirely wrong here, but this is what I see and my readings more or less confirm it. If you see an error in my thinking, please post and let me know. Thanks, Tom Attached thumbnail(s) |
GregAmy |
Jul 29 2019, 02:51 PM
Advanced Member Group: Members Posts: 2,370 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
That's some beautiful stuff right there (along with the prior posts).
So lemme ask two unrelated alternator questions. - After posting, I took the racer out for a spin to check the drivetrain install (it's a caged racer but actually has plates and insurance). I was just cruising 5-10 minutes locally so didn't "excite" the alternator (not worried about battery level) but 5 minutes into the drive I glanced down and the dash was showing 13.5V. How did this happen, and is it possible that this is a non-problem for a higher-revving race car? - In the street car, I had a glowing GEN light that would be dim at idle and get brighter with RPM. I did some voltage checks and found that the B+ battery voltage was ~13.5V so it was charging fine, but the D+ voltage was full alternator output, from ~14.5V at idle to ~17+V at 3000 RPM. I drove it like that for a few months until I got motivated to replaced the alternator (the only thing the D+ was going to was the GEN light); a new voltage regulator did not resolve it, but a replacement alternator did. Why is that? What failed in the alternator for that to happen? |
Lo-Fi Version | Time is now: 18th September 2024 - 07:20 PM |
