Joshlm |
Newbie ![]() Group: Members Posts: 3 Joined: 16-March 19 From: Clovis CA Member No.: 22,964 Region Association: Central California ![]() |
So 2 days ago I was driving my 914, was doing fine all day and then I came home and about 20min later I went to start it and nothing. It’s not cranking at all. I charged and checked the battery, it’s fine (12.7v , Under load it’s 12.2v). I tried tapping the starter solenoid and nothing. I used screwdrivers to check and when I made a contact between 2 points on the solenoid I got a buzzing sounds does this mean my starter is fine? The car did not crank, but I heard the starter operating. When I made a connection between the actual starter and the solenoid I just got sparks.
With the key on accessory mode the radio and electronic work. Recently the generator light went out but I haven’t had a chance to look at it. I checked the voltage at the solenoid and it was fine (12.7). I can’t check my earths right now because my multimeter doesn’t have the continuity option (it’s the $7 harbor freight one). Does 72 have the under passenger seat relays? I didn’t see anything under the seat in my car. What do I need to test / check on my relays in the engine compartment? And does that yellow wire need to be connected to the solenoid? I didn’t see anywhere it would have mounted. Thanks in advance 72’ 1.8 ![]() |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
You need to clean your relay board and all that goes with that. The leaf is a nice touch.
Lo-Fi Version | Time is now: 26th June 2024 - 03:45 AM |
