tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,332 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
Hi World - I need some info:
I'm working to add A/C to my build and I found this little set up that's 10.5" wide, 8.5" deep and 4.5" tall. What I don't know is what's possible in terms of orientation of these evaporator/ fan units. I know they have to drain any condensation (and not into the motor, etc.) but assuming I address that: - Is there any appreciable impact to how the evap unit performs if it were stood on end, turned upside down, etc.? Essentially, does refrigerant care about flowing up vs down vs sideways? - Do any of the other components, like the expansion valve, care about orientation? If needed, I'm totally OK with cutting up the case, making one that suites my needs and reusing the components. Or, if there are other considerations, if I'm missing something, please let me know. Thanks in advance for any help! Chris Attached thumbnail(s) ![]() |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
The case should have some kind of drain port you can use to orient it. Apart from that it shouldn't matter how you mount it. The best spot I found is either directly where the wipers are (no go for wipers) or where I'm mounting mine (glove box area cut into the firewall).
You can go all project Binky on us and totally make a custom housing to fit somewhere but it's all about those fans as they are the bulky item. |
tygaboy |
The case should have some kind of drain port you can use to orient it. Apart from that it shouldn't matter how you mount it. The best spot I found is either directly where the wipers are (no go for wipers) or where I'm mounting mine (glove box area cut into the firewall). You can go all project Binky on us and totally make a custom housing to fit somewhere but it's all about those fans as they are the bulky item. Thanks Andrew. I've started looking at DC brushless fans to replace the squirrel cage set up. There are some ~ 5" x 5" X 1.5" that appear to have adequate CFM. Something like this would really open up where I could fit it and might allow me to totally hide it. I'm pretty sure I can make this work and not have to cut into the front fire wall. "Film at 11:00" as I futz with all this. Thanks again! |
Andyrew |
The case should have some kind of drain port you can use to orient it. Apart from that it shouldn't matter how you mount it. The best spot I found is either directly where the wipers are (no go for wipers) or where I'm mounting mine (glove box area cut into the firewall). You can go all project Binky on us and totally make a custom housing to fit somewhere but it's all about those fans as they are the bulky item. Thanks Andrew. I've started looking at DC brushless fans to replace the squirrel cage set up. There are some ~ 5" x 5" X 1.5" that appear to have adequate CFM. Something like this would really open up where I could fit it and might allow me to totally hide it. I'm pretty sure I can make this work and not have to cut into the front fire wall. "Film at 11:00" as I futz with all this. Thanks again! I tried some computer fans like that. Didnt blow nearly any air. A remote mount centrifugal fan might be the best. I have a bilge fan I considered using but after some more trial I ended up just cutting everything out and mounting the whole universal unit. Or at least I wanted to make sure I had room for that when designing the dash. |
Lo-Fi Version | Time is now: 26th June 2024 - 05:33 AM |
