Adding a 915 trans to a 6 conversion, There must be a better way |
mepstein |
Nov 5 2016, 07:46 AM
914-6 GT in waiting Group: Members Posts: 19,597 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Is there any reason I shouldn't consider working up a cable shifter instead of the traditional 916 shift linkage. The current 916 kit is $3-3250. Add in labor for machining and assembly and you're at $5k just to make the trans shift correctly. The suby guys are doing the shifting with $300 worth of cables and hardware. Am I missing something here?
aturboman |
Aug 5 2019, 11:04 AM
Member Group: Members Posts: 144 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
Good timing on this topic figured I'd share my 915-916 saga.
Picked up my completed trans Saturday after a 3+ year odyssey collecting parts and more importantly finding an experienced builder. 915 Mechanical speedo box, 7:31 Quiafe LSD, oil cooling and spray bar system, and Bott conversion kit, updated bearing saddle. I'm going to a hydraulic clutch, with modified 1972 only 915/901 style shifter. Here is my hydraulic pedal cluster using only factory Porsche parts including G50 pedal box as a basis This is not an inexpensive endeavor to say the least but very close to the factory 916 set-up plus some performance / reliabilty updates. |
Lo-Fi Version | Time is now: 25th November 2024 - 02:20 PM |
