advman89 |
Member ![]() ![]() Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest ![]() ![]() |
When I pulled the tires off this weekend to bleed the brakes...found that the parking brake was not connected to the caliper on either side.
I have searched for the parts to connect the cables, but can't seem to locate them. ![]() ![]() |
mbseto |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,255 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States ![]() |
Until you get the correct parts, you can just use a small bolt the size of the hole in the cable end........ Be careful to adjust cables so the bolts/pins just begin to touch the lever and not move it from their resting position more than 1/16".... GN Any reason this wouldn't work long term if it is not a show car? |
defianty |
Senior Member ![]() ![]() ![]() Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None ![]() ![]() |
Until you get the correct parts, you can just use a small bolt the size of the hole in the cable end........ Be careful to adjust cables so the bolts/pins just begin to touch the lever and not move it from their resting position more than 1/16".... GN Any reason this wouldn't work long term if it is not a show car? Having the pin enables the end of the handbrake cable to rotate slightly as the angle changes when the cable is pulled. If you tighten a bolt though it won't be able to rotate. However saying that on one of mine did have a bolt with a nyloc nut on that wasn't done up all the way. It worked but obviously not correct. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:37 AM |
