Another timing mark, Question sorry |
shane |
Aug 6 2019, 09:19 PM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
Trying to start my previously running engine after putting new seals everywhere and reinstalling it and my distributor. My distributor only goes in one way and clamps to the mounting bracket so it never moved it’s original position. So I put it in and just pulled #1 plug and watched it go to TDC on compression stroke. The rotor is pointing pretty closely to the contact on the distributor tower I have the #1 plug wire on. And have the wires on the cap CW 1-4-3-2. But can’t see the O at TDC Only this red notch and mark that was there when I bought the car. Now I’m even more confused because the pictures I’ve been looking at the red mark 27° mark doesn’t match the location it is on my fan. The red mark/notch in the pictures is next to a wide support fin, and mine isn’t. Any thoughts would be appreciated very much. It’s a 74 1.8 when I try to start it up it sputters and totally acts way out of time popping out of the carb a bit.
Mblizzard |
Aug 7 2019, 07:36 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Attached is a template that lists the timing marks.
914_timing.pdf ( 14.07k ) Number of downloads: 149 Attached below is a 2.0 impeller. It is possible to put the dizzy in 180 degrees out The way to verify if you are on TDC of the firing stroke of the #1 cylinder - pop the valve cover off the #1 side and both rockers should be loose. If not, spin the engine 360 and check again. Attached image(s) |
porschetub |
Aug 7 2019, 02:39 PM
Advanced Member Group: Members Posts: 4,729 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Attached is a template that lists the timing marks. 914_timing.pdf ( 14.07k ) Number of downloads: 149 Attached below is a 2.0 impeller. It is possible to put the dizzy in 180 degrees out The way to verify if you are on TDC of the firing stroke of the #1 cylinder - pop the valve cover off the #1 side and both rockers should be loose. If not, spin the engine 360 and check again. The fan I'am using is a bus one as its all I have with my current build,they or most have the "0" marked and nothing else,Haynes manual states measuring 52.5mm and you get 27 degrees but that is for a FI motor,I will most likely mark to get 30 degrees as running carbs. Cheers for that info Mike. |
Mblizzard |
Aug 7 2019, 07:48 PM
Attached is a template that lists the timing marks. 914_timing.pdf ( 14.07k ) Number of downloads: 149 Attached below is a 2.0 impeller. It is possible to put the dizzy in 180 degrees out The way to verify if you are on TDC of the firing stroke of the #1 cylinder - pop the valve cover off the #1 side and both rockers should be loose. If not, spin the engine 360 and check again. The fan I'am using is a bus one as its all I have with my current build,they or most have the "0" marked and nothing else,Haynes manual states measuring 52.5mm and you get 27 degrees but that is for a FI motor,I will most likely mark to get 30 degrees as running carbs. Cheers for that info Mike. To be clear I wish al, of what I posted was my brain. But the info was posted by a number of 914 people much smarter than me. I just happened to download that info. While I am remiss at not giving appropriate credit to those that came up with the info. It is al! Part of this great community. |
Lo-Fi Version | Time is now: 22nd November 2024 - 10:53 PM |
