> Turbo valve cover modification for installation in a 6, Anybody done it?
bdstone914
post Sep 18 2015, 08:42 AM
bdstone914
I have a customer who wants to add billet lower valve covers to a 6 conversion. He had one machine shop botch the first pair. Anybody done this and know how much material needs to be removed to clear the suspension point? I drawing showing the area to machined and the finished thickness would be ideal.
Please pm me if you can help
post Aug 7 2019, 10:09 PM
very simple, get an electric grinder with a flapper grinding wheel and take it down similar to what gereed75 showed in his post. goes pretty fast check as you go.
bdstone914   Turbo valve cover modification for installation in a 6   Sep 18 2015, 08:42 AM
Luke M   Had this done not too long ago. The machine shop s...   Sep 18 2015, 10:01 AM
mepstein   scotty b did mine at his local shop. 5/16". I...   Sep 18 2015, 10:26 AM
Mark Henry   Turbo covers are heavy, you likely could take the ...   Sep 18 2015, 10:52 AM
rgalla9146   Turbo covers are heavy, you likely could take the...   Sep 19 2015, 08:32 AM
Mark Henry   [quote name='Mark Henry' post='2239216' date='Sep...   Sep 19 2015, 09:56 AM
mepstein   heres what scotty did.   Sep 18 2015, 11:08 AM
396   No need to shave the whole valve cover. The exten...   Sep 18 2015, 06:54 PM
gereed75   No need to shave the whole valve cover. The exte...   Sep 18 2015, 07:27 PM
pete000   No need to shave the whole valve cover. The ext...   Sep 19 2015, 12:08 AM
moriarty   No need to shave the whole valve cover. The ext...   Feb 5 2024, 08:10 AM
porschetub   No need to shave the whole valve cover. The exte...   Sep 18 2015, 07:27 PM
Mark Henry   No need to shave the whole valve cover. The exte...   Sep 18 2015, 09:38 PM
bigkensteele   As far as being weaker the Capt'n used to alw...   Sep 18 2015, 09:50 PM
porschetub   No need to shave the whole valve cover. The ext...   Sep 18 2015, 11:23 PM
colingreene   i could do it, its not exactly hard.   Sep 19 2015, 03:37 AM
gms   If you are not hung up on the O.E. look I highly r...   Sep 19 2015, 11:24 AM
Mark Henry   If you are not hung up on the O.E. look I highly ...   Sep 19 2015, 12:40 PM
ClayPerrine   If you are not hung up on the O.E. look I highly...   Aug 6 2019, 08:51 PM
Maltese Falcon   For easier removal of the valve cover near the tra...   Sep 19 2015, 01:10 PM
Downunderman   I took out all the studs and used flange bolts. S...   Sep 19 2015, 02:25 PM
UROpartsman   If anyone has been considering this upgrade, URO j...   Aug 6 2019, 12:41 PM
burton73   What I have on my 6 #41 Bob B   Aug 6 2019, 09:32 PM
914043   very simple, get an electric grinder with a flappe...   Aug 7 2019, 10:09 PM
914Toy   very simple, get an electric grinder with a flapp...   Aug 8 2019, 08:12 PM
raynekat   Fins are NOT on the turbo covers for cooling. They...   Aug 8 2019, 01:38 PM
ClayPerrine   Fins are NOT on the turbo covers for cooling. The...   Aug 8 2019, 04:53 PM
porschetub   Fins are NOT on the turbo covers for cooling. The...   Aug 9 2019, 05:12 PM
t collins   I milled mine down to just above the bosses using ...   Aug 8 2019, 07:37 PM
UROpartsman   Auto Atlanta just added them to their web site, se...   Aug 9 2019, 10:34 AM
Mark Henry   Auto Atlanta just added them to their web site, s...   Aug 9 2019, 03:07 PM
fixer34   Been there, done that 5+ years ago when I replaced...   Aug 9 2019, 08:38 PM
mb911   You should NOT be required to machine the covers t...   Aug 10 2019, 11:23 AM
mepstein   Both sides   Feb 5 2024, 08:42 AM
moriarty   Both sides OK. Thanks for the info, i'll get...   Feb 8 2024, 06:01 AM
fixer34   My pictures are a couple posts earlier, I don...   Feb 5 2024, 12:59 PM
nditiz1   When I swapped to turbo covers, I only had an issu...   Feb 8 2024, 07:00 AM
brant   Every car is slightly different It could also mat...   Feb 8 2024, 08:13 AM
- Lo-Fi Version Time is now: 20th April 2025 - 12:15 AM
