> Turbo valve cover modification for installation in a 6, Anybody done it?
bdstone914
post Sep 18 2015, 08:42 AM
bdstone914
I have a customer who wants to add billet lower valve covers to a 6 conversion. He had one machine shop botch the first pair. Anybody done this and know how much material needs to be removed to clear the suspension point? I drawing showing the area to machined and the finished thickness would be ideal.
Please pm me if you can help
raynekat
post Aug 8 2019, 01:38 PM
Fins are NOT on the turbo covers for cooling.
They are there to add structural stiffness so the covers don't warp as easily as the earlier covers tended to do.
I think a bigger problem with any cover warping is that the owner doesn't change out the gaskets enough when there are leaks and instead tries to tighten the dickens out of the covers....that's what really warps them.
I would just remove enough material to get the turbo covers to clear the suspension ear as in post #7 and leave the rest of the rib material alone.
bdstone914   Turbo valve cover modification for installation in a 6   Sep 18 2015, 08:42 AM
Luke M   Had this done not too long ago. The machine shop s...   Sep 18 2015, 10:01 AM
mepstein   scotty b did mine at his local shop. 5/16". I...   Sep 18 2015, 10:26 AM
Mark Henry   Turbo covers are heavy, you likely could take the ...   Sep 18 2015, 10:52 AM
rgalla9146   Turbo covers are heavy, you likely could take the...   Sep 19 2015, 08:32 AM
Mark Henry   [quote name='Mark Henry' post='2239216' date='Sep...   Sep 19 2015, 09:56 AM
mepstein   heres what scotty did.   Sep 18 2015, 11:08 AM
396   No need to shave the whole valve cover. The exten...   Sep 18 2015, 06:54 PM
gereed75   No need to shave the whole valve cover. The exte...   Sep 18 2015, 07:27 PM
pete000   No need to shave the whole valve cover. The ext...   Sep 19 2015, 12:08 AM
moriarty   No need to shave the whole valve cover. The ext...   Feb 5 2024, 08:10 AM
porschetub   No need to shave the whole valve cover. The exte...   Sep 18 2015, 07:27 PM
Mark Henry   No need to shave the whole valve cover. The exte...   Sep 18 2015, 09:38 PM
bigkensteele   As far as being weaker the Capt'n used to alw...   Sep 18 2015, 09:50 PM
porschetub   No need to shave the whole valve cover. The ext...   Sep 18 2015, 11:23 PM
colingreene   i could do it, its not exactly hard.   Sep 19 2015, 03:37 AM
gms   If you are not hung up on the O.E. look I highly r...   Sep 19 2015, 11:24 AM
Mark Henry   If you are not hung up on the O.E. look I highly ...   Sep 19 2015, 12:40 PM
ClayPerrine   If you are not hung up on the O.E. look I highly...   Aug 6 2019, 08:51 PM
Maltese Falcon   For easier removal of the valve cover near the tra...   Sep 19 2015, 01:10 PM
Downunderman   I took out all the studs and used flange bolts. S...   Sep 19 2015, 02:25 PM
UROpartsman   If anyone has been considering this upgrade, URO j...   Aug 6 2019, 12:41 PM
burton73   What I have on my 6 #41 Bob B   Aug 6 2019, 09:32 PM
914043   very simple, get an electric grinder with a flappe...   Aug 7 2019, 10:09 PM
914Toy   very simple, get an electric grinder with a flapp...   Aug 8 2019, 08:12 PM
raynekat   Fins are NOT on the turbo covers for cooling. They...   Aug 8 2019, 01:38 PM
ClayPerrine   Fins are NOT on the turbo covers for cooling. The...   Aug 8 2019, 04:53 PM
porschetub   Fins are NOT on the turbo covers for cooling. The...   Aug 9 2019, 05:12 PM
t collins   I milled mine down to just above the bosses using ...   Aug 8 2019, 07:37 PM
UROpartsman   Auto Atlanta just added them to their web site, se...   Aug 9 2019, 10:34 AM
Mark Henry   Auto Atlanta just added them to their web site, s...   Aug 9 2019, 03:07 PM
fixer34   Been there, done that 5+ years ago when I replaced...   Aug 9 2019, 08:38 PM
mb911   You should NOT be required to machine the covers t...   Aug 10 2019, 11:23 AM
mepstein   Both sides   Feb 5 2024, 08:42 AM
moriarty   Both sides OK. Thanks for the info, i'll get...   Feb 8 2024, 06:01 AM
fixer34   My pictures are a couple posts earlier, I don...   Feb 5 2024, 12:59 PM
nditiz1   When I swapped to turbo covers, I only had an issu...   Feb 8 2024, 07:00 AM
brant   Every car is slightly different It could also mat...   Feb 8 2024, 08:13 AM
- Lo-Fi Version Time is now: 20th April 2025 - 12:15 AM
