jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
The yellow start wire at the ignition switch goes to the #1 position on the 14 pin relay board in the engine bay; I already have the bypass eliminated under the pass seat.
From here I get confused as to the path from the relay board, the dual relay, and finally the starter. I have a hot-start relay mounted by the starter. Car starts fine, Attached image(s) ![]() |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Have you studied the schematic Jim? That yellow wire is a circuit between the relay board and double relay.
Lo-Fi Version | Time is now: 26th June 2024 - 12:29 AM |
