> Subaru conversion from a Buick swap
Darrensells
post Aug 23 2019, 03:19 AM
I recently purchased a 1970 914 that was converted to a 3.8 Buick in 1982 but only completed to 90% finished. I am almost finished but the engine has to come out due to timing cover gasket leaking. I am considering changing it all out to a Subaru 6cyl and 5speed Subaru transmission. What donor car should I seek to complete this project? Can I use the engine cradle from the 3.8 Buick? Will it be modifiable? Thanks.
914forme
post Aug 25 2019, 11:40 AM
3.8 GM engine is a fine engine, I would go EFI and supercharged if you want to make something odd and interesting. Stock it is 240HP, a PCM and a pulley swap and you are getting closer to 270 if you think you need it.
240 is a pretty decent number in a 914
Engine is darn near bullet proof, except the latter ones that switched to a plastic water inlet manifold. But most of them have been fixed by now.
Darrensells
post Aug 25 2019, 11:57 AM
QUOTE(914forme @ Aug 25 2019, 12:40 PM) *
Do I need to change over the intake on these fwd 3800 SC engines? What I have read is you need the RWD Camaro upper and lower intake. Thanks. This would be much faster to build and more economical.
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 08:11 AM
