Lost my bearings, RWL bearings |
jwalters |
Dec 2 2004, 05:04 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:style_emoticons/default/ohmy.gif) Need some input please. When I replaced my rwl bearings on my daily driver, they were from pep-boys, do not remember the brand but was U.S.A. They went in w/o a hitch, and when torqued had what I thouroughly believed as beautiful feeling pre-load. No noises when turned, easy to turn w/ some resistance--now those are not bothering me, this is:
When I got my spare (rear) arms built up, I had gotten some more new bearings (SKF brand , made in Spain) for my rebuild project. Now, I am not quite sure about them, and it sickens me (IMG:style_emoticons/default/icon8.gif) (IMG:style_emoticons/default/barf.gif) that they may have to be replaced before I even use them. See, these have little pre-load on them at all, and when I spin the hub, they emit a sound as if there is no grease in them. I loosened the nuts and double checked the torques-- (IMG:style_emoticons/default/confused24.gif) Has anybody else faced this before??? I have never in my 20+ years of wrenching come across a situation such as this. Two brand new bearings, not feeling bad, but not quite right either..... |
John |
Dec 2 2004, 10:06 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Here is my $0.02....
If in doubt, get another Pep-Boys bearing (if those are what you like) and install it. See if the "noise" is gone and if there is preload. If the noise is gone with the Pep-Boys bearing, replace the other one and be happy. In my experience, if a bearing is noisy, it will only get worse. I would tend to agree with your gut feeling that something is wrong. However, I could be wrong, and the noise may stay the same as it is which would indicate to me that it is "normal", but I kinda doubt that this is the case. Without being there and hearing the noise and feeling the hub to see if it feels like grit or something, I cannot give you any further advice. |
Lo-Fi Version | Time is now: 6th January 2025 - 07:12 PM |
