Defrost without exchangers ? |
Literati914 |
Sep 4 2019, 10:39 PM
Senior Member Group: Members Posts: 1,494 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
What are you guys without exchangers doing to de-fog your windshields? what are all options? I mean some people use a stand alone heater unit.. do those defrost also?
Superhawk996 |
Sep 5 2019, 07:23 PM
914 Guru Group: Members Posts: 5,993 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Being 20 and knowing everything. I stripped the heat exchangers off my 1st 914 to save weight along with just about anything else that wasn't welded in.
That was fine when I could afford to buy what we used to call "winter beaters" and store my 914 in the winter. Then I got out of the military and was broke. Had to drive it in the winter. Coleman propane heater strapped into the passenger seat beside me and a ice scraper withing arms reach. Forget fog, I used to get ice on the INSIDE of the windows from my breath condensing and freezing to the cold glass. Tried to usually leave a window down a crack . . . . needed to vent the CO somewhere. Definitely not recommended. (IMG:style_emoticons/default/sad.gif) Oh, and in case you didn't know, heat rises. I can't tell you how many times I arrived at a destination a few hours away with numb feet. Oh, to to be 20 again. (IMG:style_emoticons/default/happy11.gif) By and large, RainX on outside and RainX anti-fog was the way to roll but I assure you it won't always work, but, it is better than nothing at all. |
bbrock |
Sep 5 2019, 10:13 PM
Being 20 and knowing everything. I stripped the heat exchangers off my 1st 914 to save weight along with just about anything else that wasn't welded in. That was fine when I could afford to buy what we used to call "winter beaters" and store my 914 in the winter. Then I got out of the military and was broke. Had to drive it in the winter. Coleman propane heater strapped into the passenger seat beside me and a ice scraper withing arms reach. Forget fog, I used to get ice on the INSIDE of the windows from my breath condensing and freezing to the cold glass. Tried to usually leave a window down a crack . . . . needed to vent the CO somewhere. Definitely not recommended. (IMG:style_emoticons/default/sad.gif) Oh, and in case you didn't know, heat rises. I can't tell you how many times I arrived at a destination a few hours away with numb feet. Oh, to to be 20 again. (IMG:style_emoticons/default/happy11.gif) By and large, RainX on outside and RainX anti-fog was the way to roll but I assure you it won't always work, but, it is better than nothing at all. Sounds a lot like our old 74 VW bus with perfectly good heat exchangers and fully functioning heating system. We would literally climb inside our sleeping bags in the winter when we went on trips, or even just driving into work. I would unzip the foot section so I could work the pedals. Heat cranked up high (what a joke), and ice scraper on the dash to periodically scrape the ice off the inside of the glass. Usually a stop or two to get out and scrape the outside of the glass too. Good times... good times.... (IMG:style_emoticons/default/lol-2.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 11:22 PM |
