> Alternator question., Not Charging.
Olympic 914
post Mar 25 2018, 05:05 PM
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner.....
Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good.
I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration.
Now the question
I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V
So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate.
OR
Leave the VR in place and short between those pins?
914Sixer
post Sep 6 2019, 02:54 PM
Adding information from owners manual. Please read information. Your last VR has a problem.
Olympic 914   Alternator question.   Mar 25 2018, 05:05 PM
Spoke   Took the car out for a drive today, planning on g...   Mar 26 2018, 07:21 AM
Olympic 914   Yes, disconnect only the VR. Jump the D+ and DF...   Mar 26 2018, 08:37 AM
falcor75   Ground cable between gearbox and chassi?   Mar 26 2018, 08:47 AM
Olympic 914   Ground cable between gearbox and chassi? New, C...   Mar 26 2018, 08:55 AM
Mikey914   Well if all works well great. I'd try driving ...   Mar 26 2018, 09:40 AM
Olympic 914   Well if all works well great. I'd try driving...   Mar 26 2018, 09:50 AM
Olympic 914   So this alternator problem continues to vex me. ...   Apr 18 2018, 07:20 PM
malcolm2   Next step will be to pull the alternator and pro...   Apr 19 2018, 08:04 AM
McMark   Dying relay board?   Apr 19 2018, 05:30 AM
Olympic 914   Dying relay board? I did hook up another relay ...   Apr 19 2018, 06:20 AM
malcolm2   I have had some ALT probs too. Spoke must keep th...   Apr 19 2018, 07:08 AM
McMark   I think malcolm2 is right -- and I don't think...   Apr 19 2018, 07:34 AM
Tdskip   I think malcolm2 is right -- and I don't thin...   Mar 28 2019, 06:13 AM
malcolm2   I am bored today. Hey Spoke, how is this???   Apr 19 2018, 09:13 AM
Olympic 914   There is also this. I performed the tests belo...   Apr 19 2018, 11:55 AM
McMark   Damn!!! That’s a fantastic post. :dr...   Apr 19 2018, 04:09 PM
bulitt   Yes, you must excite the Alternator to wake it up....   Apr 19 2018, 04:58 PM
Mikey914   Yes, you must excite the Alternator to wake it up...   Apr 20 2018, 10:20 AM
Edward Blume   I had my stock Bosch alternator professionally reb...   Apr 19 2018, 05:58 PM
jcd914   I don't recall the years but there was a TSB f...   Apr 20 2018, 10:36 AM
Olympic 914   On Thursday took the alternator to the local FLAPS...   Apr 22 2018, 11:52 AM
Spoke   :beer2:   Apr 22 2018, 12:07 PM
GregAmy   That post #15 is a gem... Camping onto this one f...   May 13 2018, 01:22 PM
Spoke   Does everyone else's GEN light come on with k...   May 13 2018, 02:20 PM
GregAmy   Yes, the light is on with key on and engine not ru...   May 13 2018, 03:45 PM
Spoke   Yes, the light is on with key on and engine not r...   May 13 2018, 05:30 PM
GregAmy   = About the measurements, here's what I think...   May 14 2018, 05:05 AM
GregAmy   = About the measurements, here's what I think...   May 14 2018, 03:55 PM
GregAmy   Camping onto this one for a slightly different pr...   Mar 25 2019, 07:58 PM
worn   Camping onto this one for a slightly different p...   Mar 25 2019, 08:13 PM
GregAmy   Maximum alternator output is triggered when you b...   Mar 26 2019, 05:06 AM
DRPHIL914   Camping onto this one for a slightly different p...   Mar 27 2019, 10:33 AM
VaccaRabite   Greg, Glad you solved it. My issue was the lacke...   Mar 27 2019, 07:39 PM
euro911   I have several 'unknown condition' units I...   May 14 2018, 02:27 AM
GregAmy   Aaaaand a new voltage regulator... ...didn't ...   May 14 2018, 04:32 PM
Spoke   Bummer. I didn't think the VR was at fault but...   May 15 2018, 07:04 PM
GregAmy   Yep. All grounds and battery cables replaced by me...   May 16 2018, 06:42 AM
dangrouche   Yep. All grounds and battery cables replaced by m...   May 17 2018, 11:27 AM
GregAmy   the pigtail at the alternator end needs the altern...   May 18 2018, 08:07 AM
dangrouche   https://www.aspwholesale.com/index.php here is a ...   May 18 2018, 11:24 AM
Gatornapper   Ok, friends - this thread has been very helpful, b...   Aug 31 2019, 07:07 PM
Spoke   Try these measurements with engine running; lights...   Aug 31 2019, 08:14 PM
Gatornapper   Only work on car had nothing to do with electrical...   Sep 1 2019, 07:20 AM
Spoke   Should I read these voltages at the VR pins as we...   Sep 1 2019, 07:48 AM
Gatornapper   I have quite a bit of experience with circuit boar...   Sep 1 2019, 11:36 AM
Gatornapper   Spoke - Ran tests tonight after 1 hour drive, so ...   Sep 3 2019, 06:26 PM
Spoke   Spoke - Ran tests tonight after 1 hour drive, so...   Sep 3 2019, 07:34 PM
Gatornapper   Spoke - yes, GEN light is OFF until I turn on head...   Sep 3 2019, 08:08 PM
914Sixer   Do you have a spare relay board to swap out?   Sep 1 2019, 07:41 AM
904svo   Just a WAG, measure the voltage between the altern...   Sep 3 2019, 07:28 PM
Gatornapper   Thanks for the idea - I'll do that. But previ...   Sep 3 2019, 07:37 PM
Gatornapper   Re: VR not working. Both VR's I have get ver...   Sep 4 2019, 06:21 AM
Olympic 914   Re: VR not working. Both VR's I have get ve...   Sep 4 2019, 06:45 AM
Gatornapper   Thanks - would like to get one.... Checked BERU...   Sep 4 2019, 09:42 AM
Spoke   Re: VR not working. Both VR's I have get ve...   Sep 4 2019, 07:06 PM
euro911   Typically can't purchase products from compani...   Sep 4 2019, 11:43 AM
Gatornapper   Thanks Mark. Typically can't purchase produc...   Sep 4 2019, 05:21 PM
Gatornapper   Ok, test results: Relay board not the problem.......   Sep 4 2019, 05:28 PM
Spoke   Ok, test results: Relay board not the problem......   Sep 4 2019, 07:24 PM
VaccaRabite   Keep in mind that without the alternator working,...   Sep 5 2019, 07:58 AM
Gatornapper   Zach - First running one to the shroud. Then ch...   Sep 5 2019, 11:03 AM
jcd914   Maybe I missed in the thread but did you check vol...   Sep 4 2019, 05:53 PM
Gatornapper   Jim - will check tomorrow, but checked all other p...   Sep 4 2019, 08:09 PM
Gatornapper   Spoke - Will run all suggested tests tomorrow - ...   Sep 4 2019, 08:23 PM
Spoke   So when I check D- to chassis that's with the...   Sep 5 2019, 04:15 AM
Gatornapper   Dumb question: if the VR is in place, where do I ...   Sep 5 2019, 10:59 AM
Spoke   Dumb question: if the VR is in place, where do I...   Sep 5 2019, 03:58 PM
Spoke   This diagram shows which signals are which. In th...   Sep 5 2019, 04:02 PM
Gatornapper   I should have told you all I don't have regula...   Sep 5 2019, 04:54 PM
Spoke   It makes me wonder if the VR is not starting becau...   Sep 5 2019, 05:41 PM
Gatornapper   Ok, I can do that, but then I need someone else at...   Sep 5 2019, 06:12 PM
Gatornapper   I have another idea: I'll bring a 1 amp fused...   Sep 5 2019, 06:18 PM
Spoke   I have another idea: I'll bring a 1 amp fuse...   Sep 5 2019, 06:41 PM
Gatornapper   Spoke - Ok, let's assume that jumping 12+ to ...   Sep 5 2019, 07:05 PM
Spoke   Spoke - Ok, let's assume that jumping 12+ to...   Sep 5 2019, 07:29 PM
Spoke   I have another idea: I'll bring a 1 amp fuse...   Sep 6 2019, 04:47 PM
Gatornapper   I have another idea: I'll bring a 1 amp fus...   Sep 7 2019, 05:46 AM
Gatornapper   Spoke - D- to engine or chassis with engine runni...   Sep 5 2019, 06:05 PM
914Sixer   Adding information from owners manual. Please rea...   Sep 6 2019, 02:54 PM
Gatornapper   Mark - yes, I know this - so I have 3 bad VR's...   Sep 6 2019, 03:34 PM
914Sixer   I would say the Bosch ones are ok. Is the alterna...   Sep 6 2019, 03:54 PM
Gatornapper   I would say yes. But remember, it puts out full v...   Sep 7 2019, 05:32 AM
Gatornapper   Post I just made on Pelican's forum: Greg - ...   Sep 7 2019, 07:15 PM
ClayPerrine   You can't use just any light for the alternato...   Sep 7 2019, 07:20 PM
Gatornapper   Clay - The 2nd VR I tried is NOS I got from a rel...   Sep 7 2019, 07:53 PM
Gatornapper   Clay - The [b]strong implication of this statemen...   Sep 8 2019, 05:54 AM
Spoke   Did you do the test with the 1156 bulb across the ...   Sep 8 2019, 09:41 AM
Gatornapper   Yes. Nothing happened. Did not energize the arma...   Sep 8 2019, 11:24 AM
Spoke   Yes. Nothing happened. Did not energize the arm...   Sep 8 2019, 04:45 PM
Gatornapper   [quote name='Gatornapper' post='2745248' date='Se...   Sep 8 2019, 06:17 PM
euro911   At this point I'm suspecting one of the altern...   Sep 8 2019, 07:25 PM
Gatornapper   Mark - Totally understand - but if one of the di...   Sep 8 2019, 07:33 PM
Spoke   At this point I'm suspecting one of the alter...   Sep 8 2019, 08:58 PM
VaccaRabite   At this point I'm suspecting one of the alte...   Sep 9 2019, 11:06 AM
Gatornapper   Memories guys? Jerry & Zack - Long ago I jump...   Sep 9 2019, 07:26 PM
Spoke   ...I jumped D+ & DF and did get full 17v at t...   Sep 9 2019, 10:50 PM
Gatornapper   Ok, will do today. One additional bit of info: G...   Sep 10 2019, 07:21 AM
Spoke   Here's a way to do a quick test on the VR. I j...   Sep 9 2019, 11:52 PM
Spoke   Part 2 of the VR test is to check the D+ and DF vo...   Sep 10 2019, 12:04 AM
- Lo-Fi Version Time is now: 26th April 2025 - 03:12 AM
