Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,732 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,154 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
It makes me wonder if the VR is not starting because of insufficient current though the GEN light. Try this test. Pull out the gauge with the GEN light. Start the engine. Carefully touch a screwdriver across the GEN bulb. This is to force the VR voltage to battery voltage. See if the alternator starts up. This shouldn't damage anything.
Don't touch the screwdriver to the case When doing this. |
Gatornapper |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,267 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States ![]() ![]() |
I have another idea: I'll bring a 1 amp fused 12+ from the battery through an 1156 bulb to D+ on the alternator plug terminal. Or a smaller lamp.......
And just touch it to energize the armature......... Whacha think? GN It makes me wonder if the VR is not starting because of insufficient current though the GEN light. Try this test. Pull out the gauge with the GEN light. Start the engine. Carefully touch a screwdriver across the GEN bulb. This is to force the VR voltage to battery voltage. See if the alternator starts up. This shouldn't damage anything. Don't touch the screwdriver to the case When doing this. |
Spoke |
I have another idea: I'll bring a 1 amp fused 12+ from the battery through an 1156 bulb to D+ on the alternator plug terminal. About the 1156 bulb with 1A fuse; the 1156 bulb will be the fuse and the load. The 1A fuse isn't needed as the 1156 bulb when put across 12V will burn about 2A. Waiting to see what happens with this test. This will see if the alternator/VR will start up with significantly more current via the 1156. If the alternator/VR does start up, then the 1156 bulb will go out. If the alternator/VR does not start up, then the 1156 bulb will continue to light. |
Gatornapper |
I have another idea: I'll bring a 1 amp fused 12+ from the battery through an 1156 bulb to D+ on the alternator plug terminal. About the 1156 bulb with 1A fuse; the 1156 bulb will be the fuse and the load. The 1A fuse isn't needed as the 1156 bulb when put across 12V will burn about 2A. I thought of that myself after I suggested the setup - no need for 2 fuses....been very busy, will try tonight..... Waiting to see what happens with this test. This will see if the alternator/VR will start up with significantly more current via the 1156. If the alternator/VR does start up, then the 1156 bulb will go out. If the alternator/VR does not start up, then the 1156 bulb will continue to light. Yup! Exactly. It will function as the GEN light...... Also doing this from Pelican's site: To trouble-shoot the problem, you need to check the various sections independently. Thus the first check: Connect +12 volts from the battery to the DF terminal on the relay board. This is the maximum field current situation, and should result in maximum output of the alternator. Note that this checks the B+ diodes, the alternator windings, and the common diodes. It does NOT check the D+ diodes. But, essentially, this is duplicating the test with the 1156, and just energizing the armature from another route - directly on the DF wire instead of through the switch in the VR...... GN |
Lo-Fi Version | Time is now: 26th April 2025 - 03:11 AM |
