| Olympic 914 |
Mar 25 2018, 05:05 PM
![]() ![]() ![]() Group: Members Posts: 1,765 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
| Spoke |
Sep 8 2019, 09:41 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,284 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Did you do the test with the 1156 bulb across the GEN light or across battery to D+? If so, what happened?
Olympic 914 Alternator question. Mar 25 2018, 05:05 PM
Spoke
Took the car out for a drive today, planning on g... Mar 26 2018, 07:21 AM
Olympic 914
Yes, disconnect only the VR. Jump the D+ and DF... Mar 26 2018, 08:37 AM
falcor75 Ground cable between gearbox and chassi? Mar 26 2018, 08:47 AM
Olympic 914
New, C... Mar 26 2018, 08:55 AM
Mikey914 Well if all works well great. I'd try driving ... Mar 26 2018, 09:40 AM
Olympic 914
Well if all works well great. I'd try driving... Mar 26 2018, 09:50 AM
Olympic 914 So this alternator problem continues to vex me. ... Apr 18 2018, 07:20 PM
malcolm2
Next step will be to pull the alternator and pro... Apr 19 2018, 08:04 AM
McMark Dying relay board? Apr 19 2018, 05:30 AM
Olympic 914
Dying relay board?
I did hook up another relay ... Apr 19 2018, 06:20 AM
malcolm2 I have had some ALT probs too. Spoke must keep th... Apr 19 2018, 07:08 AM
McMark I think malcolm2 is right -- and I don't think... Apr 19 2018, 07:34 AM
Tdskip
I think malcolm2 is right -- and I don't thin... Mar 28 2019, 06:13 AM
malcolm2 I am bored today. Hey Spoke, how is this???
Apr 19 2018, 09:13 AM
Olympic 914 There is also this.
I performed the tests belo... Apr 19 2018, 11:55 AM
McMark Damn!!! That’s a fantastic post. :dr... Apr 19 2018, 04:09 PM
bulitt Yes, you must excite the Alternator to wake it up.... Apr 19 2018, 04:58 PM
Mikey914
Yes, you must excite the Alternator to wake it up... Apr 20 2018, 10:20 AM
Edward Blume I had my stock Bosch alternator professionally reb... Apr 19 2018, 05:58 PM
jcd914 I don't recall the years but there was a TSB f... Apr 20 2018, 10:36 AM
Olympic 914 On Thursday took the alternator to the local FLAPS... Apr 22 2018, 11:52 AM
Spoke :beer2: Apr 22 2018, 12:07 PM
GregAmy That post #15 is a gem...
Camping onto this one f... May 13 2018, 01:22 PM
Spoke
Does everyone else's GEN light come on with k... May 13 2018, 02:20 PM
GregAmy Yes, the light is on with key on and engine not ru... May 13 2018, 03:45 PM
Spoke
Yes, the light is on with key on and engine not r... May 13 2018, 05:30 PM
GregAmy
= About the measurements, here's what I think... May 14 2018, 05:05 AM
GregAmy
= About the measurements, here's what I think... May 14 2018, 03:55 PM
GregAmy
Camping onto this one for a slightly different pr... Mar 25 2019, 07:58 PM
worn
Camping onto this one for a slightly different p... Mar 25 2019, 08:13 PM
GregAmy
Maximum alternator output is triggered when you b... Mar 26 2019, 05:06 AM
DRPHIL914
Camping onto this one for a slightly different p... Mar 27 2019, 10:33 AM
VaccaRabite
Greg,
Glad you solved it. My issue was the lacke... Mar 27 2019, 07:39 PM
euro911 I have several 'unknown condition' units I... May 14 2018, 02:27 AM
GregAmy Aaaaand a new voltage regulator...
...didn't ... May 14 2018, 04:32 PM
Spoke Bummer. I didn't think the VR was at fault but... May 15 2018, 07:04 PM
GregAmy Yep. All grounds and battery cables replaced by me... May 16 2018, 06:42 AM
dangrouche
Yep. All grounds and battery cables replaced by m... May 17 2018, 11:27 AM
GregAmy the pigtail at the alternator end needs the altern... May 18 2018, 08:07 AM
dangrouche https://www.aspwholesale.com/index.php
here is a ... May 18 2018, 11:24 AM
Gatornapper Ok, friends - this thread has been very helpful, b... Aug 31 2019, 07:07 PM
Spoke Try these measurements with engine running; lights... Aug 31 2019, 08:14 PM
Gatornapper Only work on car had nothing to do with electrical... Sep 1 2019, 07:20 AM
Spoke
Should I read these voltages at the VR pins as we... Sep 1 2019, 07:48 AM
Gatornapper I have quite a bit of experience with circuit boar... Sep 1 2019, 11:36 AM
Gatornapper Spoke -
Ran tests tonight after 1 hour drive, so ... Sep 3 2019, 06:26 PM
Spoke
Spoke -
Ran tests tonight after 1 hour drive, so... Sep 3 2019, 07:34 PM
Gatornapper Spoke - yes, GEN light is OFF until I turn on head... Sep 3 2019, 08:08 PM
914Sixer Do you have a spare relay board to swap out? Sep 1 2019, 07:41 AM
904svo Just a WAG, measure the voltage between the altern... Sep 3 2019, 07:28 PM
Gatornapper Thanks for the idea - I'll do that. But previ... Sep 3 2019, 07:37 PM
Gatornapper Re: VR not working.
Both VR's I have get ver... Sep 4 2019, 06:21 AM
Olympic 914
Re: VR not working.
Both VR's I have get ve... Sep 4 2019, 06:45 AM
Gatornapper Thanks - would like to get one....
Checked BERU... Sep 4 2019, 09:42 AM
Spoke
Re: VR not working.
Both VR's I have get ve... Sep 4 2019, 07:06 PM
euro911 Typically can't purchase products from compani... Sep 4 2019, 11:43 AM
Gatornapper Thanks Mark.
Typically can't purchase produc... Sep 4 2019, 05:21 PM
Gatornapper Ok, test results:
Relay board not the problem....... Sep 4 2019, 05:28 PM
Spoke
Ok, test results:
Relay board not the problem...... Sep 4 2019, 07:24 PM
VaccaRabite
Keep in mind that without the alternator working,... Sep 5 2019, 07:58 AM
Gatornapper Zach -
First running one to the shroud. Then ch... Sep 5 2019, 11:03 AM
jcd914 Maybe I missed in the thread but did you check vol... Sep 4 2019, 05:53 PM
Gatornapper Jim - will check tomorrow, but checked all other p... Sep 4 2019, 08:09 PM
Gatornapper Spoke -
Will run all suggested tests tomorrow - ... Sep 4 2019, 08:23 PM
Spoke
So when I check D- to chassis that's with the... Sep 5 2019, 04:15 AM
Gatornapper Dumb question: if the VR is in place, where do I ... Sep 5 2019, 10:59 AM
Spoke
Dumb question: if the VR is in place, where do I... Sep 5 2019, 03:58 PM
Spoke This diagram shows which signals are which.
In th... Sep 5 2019, 04:02 PM
Gatornapper I should have told you all I don't have regula... Sep 5 2019, 04:54 PM
Spoke It makes me wonder if the VR is not starting becau... Sep 5 2019, 05:41 PM
Gatornapper Ok, I can do that, but then I need someone else at... Sep 5 2019, 06:12 PM
Gatornapper I have another idea: I'll bring a 1 amp fused... Sep 5 2019, 06:18 PM
Spoke
I have another idea: I'll bring a 1 amp fuse... Sep 5 2019, 06:41 PM
Gatornapper Spoke -
Ok, let's assume that jumping 12+ to ... Sep 5 2019, 07:05 PM
Spoke
Spoke -
Ok, let's assume that jumping 12+ to... Sep 5 2019, 07:29 PM
Spoke
I have another idea: I'll bring a 1 amp fuse... Sep 6 2019, 04:47 PM
Gatornapper
I have another idea: I'll bring a 1 amp fus... Sep 7 2019, 05:46 AM
Gatornapper Spoke -
D- to engine or chassis with engine runni... Sep 5 2019, 06:05 PM
914Sixer Adding information from owners manual. Please rea... Sep 6 2019, 02:54 PM
Gatornapper Mark - yes, I know this - so I have 3 bad VR's... Sep 6 2019, 03:34 PM
914Sixer I would say the Bosch ones are ok. Is the alterna... Sep 6 2019, 03:54 PM
Gatornapper I would say yes.
But remember, it puts out full v... Sep 7 2019, 05:32 AM
Gatornapper Post I just made on Pelican's forum:
Greg -
... Sep 7 2019, 07:15 PM
ClayPerrine You can't use just any light for the alternato... Sep 7 2019, 07:20 PM
Gatornapper Clay -
The 2nd VR I tried is NOS I got from a rel... Sep 7 2019, 07:53 PM
Gatornapper Clay -
The [b]strong implication of this statemen... Sep 8 2019, 05:54 AM
Gatornapper Yes. Nothing happened. Did not energize the arma... Sep 8 2019, 11:24 AM
Spoke
Yes. Nothing happened. Did not energize the arm... Sep 8 2019, 04:45 PM
Gatornapper
[quote name='Gatornapper' post='2745248' date='Se... Sep 8 2019, 06:17 PM
euro911 At this point I'm suspecting one of the altern... Sep 8 2019, 07:25 PM
Gatornapper Mark -
Totally understand - but if one of the di... Sep 8 2019, 07:33 PM
Spoke
At this point I'm suspecting one of the alter... Sep 8 2019, 08:58 PM
VaccaRabite
At this point I'm suspecting one of the alte... Sep 9 2019, 11:06 AM
Gatornapper Memories guys? Jerry & Zack - Long ago I jump... Sep 9 2019, 07:26 PM
Spoke
...I jumped D+ & DF and did get full 17v at t... Sep 9 2019, 10:50 PM
Gatornapper Ok, will do today.
One additional bit of info: G... Sep 10 2019, 07:21 AM
Spoke Here's a way to do a quick test on the VR. I j... Sep 9 2019, 11:52 PM
Spoke Part 2 of the VR test is to check the D+ and DF vo... Sep 10 2019, 12:04 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th December 2025 - 05:27 AM |
