> Gas line issue, sprung a leak
johnpierre
post Sep 16 2019, 12:12 PM
hey everyone
its been a while - but im in need of some help. my fuel line sprung a leak. i notice a big puddle under the passenger side seat. when investigated i could smell gas. then i tried to start is and no luck out of gas.
has this happened to anyone? is it as simple as just replacing the fuel line itstelf or can i just repair the area that is leaking?
is this a straight forward/simple job that i can perform myself or is it for a true mechanic?
please advice, much appreciated...
-jp-
johnpierre
post Sep 17 2019, 03:40 PM
hey everyone
thanks for the reply's and help I will jack the car up and see if it is the lines or the filter as pointed out - will reply with the results soon. i know i could count on y'all (IMG:style_emoticons/default/aktion035.gif)
johnpierre   Gas line issue   Sep 16 2019, 12:12 PM
bretth   First of all don't try to start it anymore unt...   Sep 16 2019, 12:53 PM
anderssj   hey everyone i notice a big puddle under the pa...   Sep 16 2019, 01:06 PM
rjames   Please report back on what line is the culprit. I ...   Sep 16 2019, 01:37 PM
porschetub   Most likely the rubber lines of the plastic ones ,...   Sep 16 2019, 01:56 PM
mepstein   I would replace every rubber and plastic line you ...   Sep 16 2019, 03:15 PM
burton73   I would replace every rubber and plastic line you...   Sep 16 2019, 04:07 PM
johnpierre   I would replace every rubber and plastic line yo...   Oct 3 2019, 10:43 PM
SirAndy   ... then i tried to start is and no luck out of ga...   Sep 16 2019, 04:58 PM
Tbrown4x4   An expensive repair , but weighed against the pric...   Sep 16 2019, 11:17 PM
Rand   Let this be clear. The problems with fuel systems ...   Sep 16 2019, 11:21 PM
ClayPerrine   Let this be clear. The problems with fuel systems...   Sep 18 2019, 05:50 AM
johnpierre   Let this be clear. The problems with fuel system...   Sep 19 2019, 12:44 AM
defianty   The problem is not the lines in the tunnel, it i...   Sep 19 2019, 02:28 AM
porschetub   :agree: my plastic stuff was fine,however my car h...   Sep 17 2019, 01:12 AM
cuddy_k   There's a video on how to replace the fuel lin...   Sep 17 2019, 01:16 AM
Tbrown4x4   You said, "i notice a big puddle under the pa...   Sep 17 2019, 02:53 AM
johnpierre   hey everyone thanks for the reply's and help...   Sep 17 2019, 03:40 PM
Mikey914   My money is on the rubber. I had a similar experie...   Oct 3 2019, 11:54 PM
JawjaPorsche   I had a rare leak in the plastic tunnel lines. I ...   Oct 4 2019, 04:06 AM
gandalf_025   I pulled my fuel lines out while my car is apart.....   Oct 4 2019, 09:27 AM
JawjaPorsche   I pulled my fuel lines out while my car is apart....   Oct 4 2019, 11:24 AM
euro911   Robert ( @rotary'14 ) also makes stainless ste...   Oct 25 2020, 11:01 AM
- Lo-Fi Version Time is now: 7th January 2025 - 12:31 PM
