case cylinder hold down bolts, removal |
jb57tub |
Sep 16 2019, 08:50 PM
jb57tub Group: Members Posts: 23 Joined: 9-January 19 From: Corpus Christi, Tx Member No.: 22,790 Region Association: Southwest Region |
Should I use a little heat at the case halves to remove the cylinder hold down bolts? The case halves are not being reused. double nutting the bolts for removal. Removal all other studs will be done the same way. Thanks Jon
Superhawk996 |
Sep 17 2019, 05:17 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
The oil strainer pick up bolt is not part of the case itself.
Lo-Fi Version | Time is now: 21st September 2024 - 10:03 PM |
