dgale914 |
Newbie ![]() Group: Members Posts: 10 Joined: 5-March 03 Member No.: 395 Region Association: Northern California ![]() |
Hey guys,
I ran across some old threads on this but wasn't able to get the answers I was looking for. Hence the need to post this message. I recently picked up a full tube chassis 914 that was set-up for a water cooled V8. I have a Bill Mitchell small block chevy 'Motown' 427 cubic inch motor laying around and a Boxster 6 speed with a Guard LSD. I have the motor & trans mated and mounted in the chassis and now I'm looking for an axle solution. Long story but the car's hubs, calipers, and rotors are all Coleman Racing stock car components with QA-1 double adjustable coilovers. It's a very well built car with very cheap consumables. The car also has 'wide 5' wheels that are commonly used on circle track cars. These are mated to the 4 lug hubs with a large billet adapter. Now that I've set the stage for what I'm dealing with I need some info around axles and CV joints. I have access to: (1) pair of 930 axles with the 108mm 6 bolt CV joints. (1) pair of early 911 axles with the 100mm CV joints. (1) pair of billet adapters to go from 914-4 4 bolt, 2 pin to 6 bolt 100mm CV I need: (1) pair of axles that will get me from the billet adapter with the 100mm 6 bolt pattern to the 108mm 6 bolt pattern. I read one thread that said that the 2000 Boxster S uses the same length shaft on both sides. I was also told by someone that you need a 1/2" spacer on one of the sides to extend that side's axle length. Not sure who is correct? Questions: 1. Is the axle shaft diameter and spline count the same between the early 911 with 100mm CV and the later 108mm? 2. If yes to #1, then is it possible to assemble a 100mm CV on the end of a 108mm 930 axle? Are the nuckle, cage and balls the same size? 3. If no to #1, then who sells an axle that would allow me to assemble a 100mm CV on one end of the shaft and a 108mm on the other end? 4. With a 2000 Boxster S transaxle, are the left and right axles the same length? If not, what lengths are required on each side? I have some early 911 5 lug hubs I could use to make a 108mm to 108mm solution but I prefer to use those on another 914-6 project. Any help you guys can provide to get from point A to B would help. Thanks Doug tmr.doug@gmail.com |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,580 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Mine is on a 2006 Cayman S six speed. The axles fit fine on a 914.
Here's a picture of the bottom of my car with the axles installed. (IMG:http://www.914world.com/bbs2/uploads/post-1143-1567132725.jpg) Mine already had the hubs and brakes installed. I just removed the 944 axles and installed the 930 axles. Everything fit with no issues. Oh.. make sure you get the right length bolts for the CV joints. Too long and they hit the side of the transaxle. Clay |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:04 PM |
