RolinkHaus |
Member ![]() ![]() Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None ![]() |
Question? Is the oil pressure switch tool a thin walled socket? Using a standard 24mm socket I am unable to remove the sensor.
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,994 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Since no picture are posted. Let's be sure we are talking the same part. I'm a bit confused since there really should be no tool access issues with getting to this sensor once the exterior cover plate is removed. Beware, removal of the two bolts will likely dump all oil if not drained and you start trying to loosen the sensor.
Here is the Taco plate located underneath the engine as shown in the Classified Forum. http://www.914world.com/bbs2/index.php?showtopic=340764 Are we absolutely talking the same parts? If so, the sensor probably isn't the issue and is more likely blocked cooling fins, blocked oil cooler, and be sure to check the fan to make sure you don't have a plastic shopping bag or other debris in the fan itself. Early temp gauges had a wide red band. The tendency to run near the red band causes lots of worry without due cause. Later temp gauges had a much narrower band almost all the way to full scale. See the difference in Kevin's link for consoles and gauges for sale. Early on left, Late on Rt. http://www.914world.com/bbs2/index.php?showtopic=340745 Are you deep in the red? |
Lo-Fi Version | Time is now: 26th June 2024 - 08:42 AM |
