RolinkHaus |
Member ![]() ![]() Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None ![]() |
Question? Is the oil pressure switch tool a thin walled socket? Using a standard 24mm socket I am unable to remove the sensor.
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Find a friend with a non contact IR thermometer to confirm oil temps. It's also possible to get rodent nest on top on engine that will make it run hot. You can check that out with a cheap USB endoscope
Lo-Fi Version | Time is now: 26th June 2024 - 08:54 AM |
