mtc911 |
Member ![]() ![]() Group: Members Posts: 65 Joined: 18-March 18 From: Atlanta Member No.: 21,978 Region Association: South East States ![]() |
So I have read a ton of threads on this topic and each one lands me with a different answer and everyone I talk to has a different t opinion
My car didn’t have oil temp sensor I ordered - the sensor plate (taco plate) - orange o ring - copper crush washers I installed and was careful not to tighten too much but wanted to make sure the Bolts were snug. All seemed fine put a few hundred miles in car - no leaks - on way to Okteenerfest huge amount of smoke - pull over immediately taco plate / o-ring is gushing oil - lost about all of the oil there. You might notice a couple of tears in the o-ring - I believe that happened when I pulled over and about burned myself trying to tighten the taco plate to stop the leak (didn’t work obviously) Could the bolts have backed out of the case? Do they need some low strength loctite on them ? What Am I missing. Pictured is what I have to install - new crush washers and new o-ring Do I need the cover and extra paper gasket? I can’t even find where to buy that additional cover anymore and I don’t think it would solve the o-ring leaking anyway. I have read to use Loctite 565 on the o-ring - is that necessary? What is the torque for the bolts? Do I need a paper gasket and the o-ring? Any help is appreciated. I’m obviously confused by all the different answers I am getting. Pictured here is what I have to install. Do I need something else? ![]() ![]() |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
565 YES great for O-rings and sealing them up.
(IMG:style_emoticons/default/poke.gif) works great on push rod seals also |
Lo-Fi Version | Time is now: 26th June 2024 - 06:07 AM |
