bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Okay, I'm about halfway through my first cut of block sanding the PPG K36 surfacer on my car. So far I'm very pleased. I have a few (not too many so far) high spot where I sanded through to bare metal. My plan is to seal the whole car with a coat of reduced PPG DPLF epoxy primer before spraying color. My assumption is that this will also suffice to re-prime those few shiny spots of bare metal, but my combination of paranoia, and lack of experience make me think it wise to make sure the brain trust agrees with this. Here's a couple examples of the spots I'm talking about - gray patches are DP50LF primer base coat but you can see two roughly dime-sized shiny spots.
roblav1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region ![]() |
Brent, agree it's feasible according to the K36 tech sheet. But the DPLF tech sheet specifies a minimum thickness over metal. One thin reduced coat probably won't do it.
I personally prefer the nicely sanding smooth K36 directly under color, at least for exterior bodywork. On the other hand, in my engine compartment, I sprayed color directly over DPLF, and it came out OK. Sooo... maybe try it. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:04 AM |
