thelogo |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None ![]() |
Got a used scion
xb 117k miles really good condition But....... Ac blow intermittently cold for hours warm for a month ...cold again for 10mins Warm. Apparently this car has a compressor that always runs . no clutch So i had my mechanic recharge the system Little to no effect ...refigerant was a" small bit low " Decided to replace the compressor next reman for 240$ Was cold for 15 mins then hot ever since Then i took it too a ac specialist he ran test both with Snap on ac tool /machine And checked all electrical related . cost 65 $ Tech said it was internal compressor failure .no pressure Guy who installed the compressor said he doubts that its defective but will refund my 240 for the reman compressor and install a compressor of my choice (oem) for no charge. Is this the right thing to do or am i missing something obvious here . If you have experience with ac please chime in |
JOEPROPER |
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States ![]() ![]() |
The description in the 1st paragraph sounds like typical ac relay failure. Very common Toyota problem. Don't know why a recharge then a new compressor was tried... Sounds like you need a different ac tech.
I would have gone to the relay first because of their frequent failures, then check system pressures and b+ to the compressor. This 5 .minute Inspection would lead you to the next step... |
Lo-Fi Version | Time is now: 26th June 2024 - 12:44 AM |
