Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,331 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
Got this idea from reading posts and solutions other members have found, while looking for my solution.
First I use just what was laying around. ![]() Then I drilled out the pressure release ball and spring on the top of the oil filter mount. (Not the mount for my engine.) ![]() Grabbed an oil filler neck with the large opening. ![]() And used a piece of fuel vent hose in the bottom of a $10 breather ![]() Put it all together ![]() Cut and added 2 fuel tank, fuel line hose nipples. With a little epoxy. ![]() Thinking this is gonna work real well ![]() A view of the passageways in the oil filter Mount. ![]() Need a good location to mount it ![]() Locate my holes ![]() Drill them out ![]() And mount ![]() Install filter ![]() Good use for a Bosch filter ![]() The breather can vent out the grill, or I could run hoses back to the carburetors ![]() Close up ![]() Use heat to bend in form fuel tank vent hose ![]() Securing it while it cools ![]() And it holds its shape ![]() Need to get the hoses to the fuel line nipples ![]() Couple rubber grommets ![]() And they slide right in ![]() From the backside, Inside the wheel well ![]() Hoses attached, The diameter of these pieces all work together. ![]() Above view Eh! ![]() Venting location ![]() All done One hose attached to the filler neck, the other attached to the oil cover box below the filler. And I ended up using another fuel nipple to a different oil filler without the large opening, it was too large for the hose to attach. ![]() I have traveled 2500 miles with this set up, the amount below is from a 500 to 600 mile trip! A lot of moisture. 99% water that didn’t go in my engine.[size=4] ![]() |
914-300Hemi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,361 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California ![]() ![]() |
Great job thinking outside the box.
Lo-Fi Version | Time is now: 27th June 2024 - 06:14 PM |
