surfdogskier |
Member ![]() ![]() Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None ![]() |
I finally had my fill of FI and ripped out the entire fuel injection in 30 minutes. I was finally able to clean my engine out nice Installed dual weber carbs. I'm going to hold on to my fuel injection if I ever change my mind or sell.
Question. I installed a new low pressure fuel pump so my lines are empty. When I turn the key, I can't hear it like my FI fuel pump. What is the best way to prime these when they are new? Everything is hooked up except for the throttle cable. Should I disconnect the fuel lines to get the air out of lines. I do not know if these are vacuumed or not is why I am asking. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,803 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
No need to remove lines,if setup right it will self prime after cranking for a while ,have you wired the pump via SirAndys method in the info section ?.
Pull your negative from the coil and crank over using a remote starter switch or second person on the key,you can check for leaks than way...safer than when its running. Good luck. |
Lo-Fi Version | Time is now: 26th April 2025 - 08:58 PM |
