surfdogskier |
Member ![]() ![]() Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None ![]() |
I finally had my fill of FI and ripped out the entire fuel injection in 30 minutes. I was finally able to clean my engine out nice Installed dual weber carbs. I'm going to hold on to my fuel injection if I ever change my mind or sell.
Question. I installed a new low pressure fuel pump so my lines are empty. When I turn the key, I can't hear it like my FI fuel pump. What is the best way to prime these when they are new? Everything is hooked up except for the throttle cable. Should I disconnect the fuel lines to get the air out of lines. I do not know if these are vacuumed or not is why I am asking. |
surfdogskier |
I did not change the setup with the wires to the existing fuel pump. I used the same ones I had in my high pressure pump from the fuel injection.
I just don't hear this fuel pump like I did my other fuel pump. |
Lo-Fi Version | Time is now: 26th April 2025 - 09:03 PM |
