> Hate me, I converted to carbs. Question about priming
surfdogskier
post Oct 22 2019, 02:14 PM
I finally had my fill of FI and ripped out the entire fuel injection in 30 minutes. I was finally able to clean my engine out nice Installed dual weber carbs. I'm going to hold on to my fuel injection if I ever change my mind or sell.
Question. I installed a new low pressure fuel pump so my lines are empty. When I turn the key, I can't hear it like my FI fuel pump. What is the best way to prime these when they are new?
Everything is hooked up except for the throttle cable. Should I disconnect the fuel lines to get the air out of lines. I do not know if these are vacuumed or not is why I am asking.
sixnotfour
post Oct 23 2019, 09:48 AM
I have the pull the plug off the no. 4 pin.
go by the picture
GregAmy
post Oct 23 2019, 10:02 AM
QUOTE(sixnotfour @ Oct 23 2019, 11:48 AM) *
go by the picture
With key on and pump running, pull the fuel pump relay. Pump should stop running.
With key on and pump running, pull the power supply relay. Pump should stop running.
Do both tests with key off.
Report results.
surfdogskier
post Oct 23 2019, 11:32 AM
QUOTE(GregAmy @ Oct 23 2019, 12:02 PM) *
go by the picture
Report results.
Fuel pump relay pulled, pump goes off.
Power supply relay, pump stays on.
GregAmy
post Oct 23 2019, 11:39 AM
QUOTE(surfdogskier @ Oct 23 2019, 01:32 PM) *
No bueno. You either have an internally-shorted relay plate or someone has been messing around with your wiring. With the power supply relay removed you should not be getting power to the fuel pump relay solenoid Pin 85 and/or relay plate pin T4b-I, the upper right in that photo above, both on same circuit.
Edit: here's a screen capture of the circuit. You can see when the PSR J16 is removed, there's no way for the fuel pump relay (J17) to get +12V at pin/circuit 85. Without that, grounding T4b-III wil have no effect on the fuel pump circuit (30 to 87; connector TT14-13 goes to fuel pump).
Edit 2: is there anything connected to the T4b-I pin, the upper right one next to the grounding wire you installed?
surfdogskier   Hate me, I converted to carbs. Question about priming   Oct 22 2019, 02:14 PM
GregAmy   What carbs? Is the pump actually running when you...   Oct 22 2019, 02:24 PM
914_teener   What carbs? Is the pump actually running when yo...   Oct 22 2019, 02:29 PM
porschetub   No need to remove lines,if setup right it will sel...   Oct 22 2019, 02:33 PM
ndfrigi   I think you just used the stock wire for fuel pump...   Oct 22 2019, 02:42 PM
surfdogskier   I did not change the setup with the wires to the e...   Oct 22 2019, 03:11 PM
bbrock   I did not change the setup with the wires to the ...   Oct 22 2019, 04:16 PM
surfdogskier   I did not change the setup with the wires to the...   Oct 22 2019, 04:18 PM
porschetub   I did not change the setup with the wires to the ...   Oct 22 2019, 04:47 PM
rhodyguy   What type of pump did you install? Rotary or facet...   Oct 22 2019, 03:47 PM
surfdogskier   What type of pump did you install? Rotary or face...   Oct 22 2019, 04:03 PM
Rand   The pressure is VERY different. Like 30psi vs 5. H...   Oct 22 2019, 03:54 PM
surfdogskier   The pressure is VERY different. Like 30psi vs 5. ...   Oct 22 2019, 04:06 PM
rhodyguy   If not done do Andy's ground wire between the ...   Oct 22 2019, 04:12 PM
Rand   "Dr 914" is here to sell you parts. You ...   Oct 22 2019, 04:16 PM
surfdogskier   "Dr 914" is here to sell you parts. You...   Oct 22 2019, 07:03 PM
Rand   I still want an explanation to why MPS was even br...   Oct 22 2019, 04:26 PM
surfdogskier   I still want an explanation to why MPS was even b...   Oct 22 2019, 04:48 PM
rhodyguy   Yes. No pump power right now.   Oct 22 2019, 04:33 PM
surfdogskier   Ok, I connected the 4 pin to the ground as mention...   Oct 22 2019, 04:53 PM
bbrock   Did you set the float levels on both carbs when yo...   Oct 22 2019, 05:58 PM
rhodyguy   Model of distributor? Go through the setup procedu...   Oct 22 2019, 06:56 PM
surfdogskier   Model of distributor? Go through the setup proced...   Oct 22 2019, 07:09 PM
surfdogskier   I am now thinking my timing is off. I am getting...   Oct 22 2019, 07:11 PM
thelogo   Carbs are king :poke:   Oct 22 2019, 07:50 PM
sixnotfour   180 out   Oct 22 2019, 08:12 PM
GregAmy   Post how you have it wired?   Oct 22 2019, 09:01 PM
surfdogskier   Post how you have it wired? I have it wired the ...   Oct 23 2019, 07:50 AM
GregAmy   Post how you have it wired? I have it wired the...   Oct 23 2019, 08:35 AM
surfdogskier   [quote name='surfdogskier' post='2756654' date='O...   Oct 23 2019, 08:52 AM
GregAmy   Edited noon for errors. I know. I did the SirAnd...   Oct 23 2019, 09:40 AM
rhodyguy   The Dansk from pelican is the quivelent of a 009? ...   Oct 23 2019, 07:15 AM
surfdogskier   The Dansk from pelican is the quivelent of a 009?...   Oct 23 2019, 07:49 AM
rhodyguy   No. 1, 4, 3, 2. Review chapter 3 of your Haynes.   Oct 23 2019, 08:11 AM
surfdogskier   No. 1, 4, 3, 2. Review chapter 3 of your Haynes. ...   Oct 23 2019, 08:53 AM
sixnotfour   go by the picture   Oct 23 2019, 09:48 AM
GregAmy   go by the picture With key on and pump runnin...   Oct 23 2019, 10:02 AM
surfdogskier   go by the picture With key on and pump runni...   Oct 23 2019, 11:32 AM
GregAmy   Fuel pump relay pulled, pump goes off. Power supp...   Oct 23 2019, 11:39 AM
Gatornapper   #1 - you need this jumper on your relay board (low...   Oct 23 2019, 10:12 AM
surfdogskier   #1 - you need this jumper on your relay board (lo...   Oct 23 2019, 06:11 PM
Literati914   "Dr 914" is here to sell you parts. Yo...   Oct 23 2019, 01:11 PM
surfdogskier   I will work on the fuel pump not shutting off afte...   Oct 23 2019, 01:35 PM
rhodyguy   Figure out where TDC on cyl #1 is. Use the engine ...   Oct 23 2019, 02:08 PM
surfdogskier   Figure out where TDC on cyl #1 is. Use the engine...   Oct 23 2019, 02:58 PM
sixnotfour   the ground needs to be #3 not #4 as before mentio...   Oct 23 2019, 02:22 PM
sixnotfour   the ground needs to be #3 not #4 as before menti...   Oct 23 2019, 06:48 PM
injunmort   sounds like you need to static time engine from th...   Oct 23 2019, 03:18 PM
IronHillRestorations   Did you turn your engine over to TDC#1 before you ...   Oct 23 2019, 04:10 PM
surfdogskier   Did you turn your engine over to TDC#1 before you...   Oct 23 2019, 04:57 PM
surfdogskier   Did you turn your engine over to TDC#1 before you...   Oct 23 2019, 04:58 PM
surfdogskier   I found the TDC on my fan. Saw where my rotor but...   Oct 23 2019, 06:08 PM
dlee6204   I found the TDC on my fan. Saw where my rotor bu...   Oct 23 2019, 06:24 PM
surfdogskier   I found the TDC on my fan. Saw where my rotor b...   Oct 23 2019, 07:33 PM
rhodyguy   Where on the cap did #1 wind up? Normally it would...   Oct 23 2019, 07:21 PM
surfdogskier   Where on the cap did #1 wind up? Normally it woul...   Oct 23 2019, 08:38 PM
- Lo-Fi Version Time is now: 26th April 2025 - 09:00 PM
