Rebel Racing Coil Overs |
Biggles |
Oct 23 2019, 11:37 AM
Member Group: Members Posts: 197 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
I’ve bought a set of rebel racing adjustable perches to go over my rear bilstein dampers.
Unfortunately, for the duel rate springs I have (tender and main spring), the isolator collar (between the two springs) ID at 54mm is just too small to go over the OD of the threaded tube, meaning I have to go up in spring size to 60mm ID I think Question: what ID springs do people use with this Rebel Racing set up and do you find the springs rub on the threaded tube ? See below Thanks, Chris Attached thumbnail(s) |
sixnotfour |
Oct 23 2019, 01:29 PM
914 Wizard Group: Members Posts: 10,598 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Or try this if the hat slides done the spring will stay seated.. Less friction on the threads ,, will thump if jumped.
Attached image(s) |
Lo-Fi Version | Time is now: 31st October 2024 - 09:31 PM |
