surfdogskier |
Member ![]() ![]() Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None ![]() |
I finally had my fill of FI and ripped out the entire fuel injection in 30 minutes. I was finally able to clean my engine out nice Installed dual weber carbs. I'm going to hold on to my fuel injection if I ever change my mind or sell.
Question. I installed a new low pressure fuel pump so my lines are empty. When I turn the key, I can't hear it like my FI fuel pump. What is the best way to prime these when they are new? Everything is hooked up except for the throttle cable. Should I disconnect the fuel lines to get the air out of lines. I do not know if these are vacuumed or not is why I am asking. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,238 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Figure out where TDC on cyl #1 is. Use the engine cooling fan mark(s). What ever location the rotor is pointing to, respective of the cap terminals, should be where the #1 plug wire goes.
For the pump. Have a look at the classic thread forum and read andy's write up. Do it exactly the same way. It works. |
surfdogskier |
Figure out where TDC on cyl #1 is. Use the engine cooling fan mark(s). What ever location the rotor is pointing to, respective of the cap terminals, should be where the #1 plug wire goes. For the pump. Have a look at the classic thread forum and read andy's write up. Do it exactly the same way. It works. So basically, pull the black plug on the cooling fan and keep just slowly turn the ignition until I see the mark on the fan. Then look at the rotor button. That will tell me the #1 cylinder......Do I have that correct? |
Lo-Fi Version | Time is now: 26th April 2025 - 09:07 PM |
