surfdogskier |
Member ![]() ![]() Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None ![]() |
I finally had my fill of FI and ripped out the entire fuel injection in 30 minutes. I was finally able to clean my engine out nice Installed dual weber carbs. I'm going to hold on to my fuel injection if I ever change my mind or sell.
Question. I installed a new low pressure fuel pump so my lines are empty. When I turn the key, I can't hear it like my FI fuel pump. What is the best way to prime these when they are new? Everything is hooked up except for the throttle cable. Should I disconnect the fuel lines to get the air out of lines. I do not know if these are vacuumed or not is why I am asking. |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,812 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Did you turn your engine over to TDC#1 before you started? If not then your distributor is probably improperly indexed/timed with TDC#1.
If you don't know where TDC#1 is, read the workshop manual for further clarification. At TDC#1 #1 piston should be at the top of it's stroke, and both valves should be fully closed, if you're not sure, then take the valve covers off and confirm. Also the rotor should point towards the front of the crankshaft. |
Lo-Fi Version | Time is now: 26th April 2025 - 08:58 PM |
