> Hate me, I converted to carbs. Question about priming
surfdogskier
post Oct 22 2019, 02:14 PM
I finally had my fill of FI and ripped out the entire fuel injection in 30 minutes. I was finally able to clean my engine out nice Installed dual weber carbs. I'm going to hold on to my fuel injection if I ever change my mind or sell.
Question. I installed a new low pressure fuel pump so my lines are empty. When I turn the key, I can't hear it like my FI fuel pump. What is the best way to prime these when they are new?
Everything is hooked up except for the throttle cable. Should I disconnect the fuel lines to get the air out of lines. I do not know if these are vacuumed or not is why I am asking.
Gatornapper
post Oct 23 2019, 10:12 AM
#1 - you need this jumper on your relay board (lower left):
(IMG:http://www.914world.com/bbs2/uploads_offsite/i890.photobucket.com-21449-1571847147.1.jpg)
#2. - you need to get a fuel pressure regulator and gauge and set the pressure to 3psi max.
My dual Weber 44's run fine with the above.
GN
QUOTE(surfdogskier @ Oct 22 2019, 02:14 PM) *
surfdogskier
post Oct 23 2019, 06:11 PM
[quote name='Gatornapper' post='2756688' date='Oct 23 2019, 12:12 PM']
GN
This didn't work in my case. Pump still stayed on.
surfdogskier   Hate me, I converted to carbs. Question about priming   Oct 22 2019, 02:14 PM
GregAmy   What carbs? Is the pump actually running when you...   Oct 22 2019, 02:24 PM
914_teener   What carbs? Is the pump actually running when yo...   Oct 22 2019, 02:29 PM
porschetub   No need to remove lines,if setup right it will sel...   Oct 22 2019, 02:33 PM
ndfrigi   I think you just used the stock wire for fuel pump...   Oct 22 2019, 02:42 PM
surfdogskier   I did not change the setup with the wires to the e...   Oct 22 2019, 03:11 PM
bbrock   I did not change the setup with the wires to the ...   Oct 22 2019, 04:16 PM
surfdogskier   I did not change the setup with the wires to the...   Oct 22 2019, 04:18 PM
porschetub   I did not change the setup with the wires to the ...   Oct 22 2019, 04:47 PM
rhodyguy   What type of pump did you install? Rotary or facet...   Oct 22 2019, 03:47 PM
surfdogskier   What type of pump did you install? Rotary or face...   Oct 22 2019, 04:03 PM
Rand   The pressure is VERY different. Like 30psi vs 5. H...   Oct 22 2019, 03:54 PM
surfdogskier   The pressure is VERY different. Like 30psi vs 5. ...   Oct 22 2019, 04:06 PM
rhodyguy   If not done do Andy's ground wire between the ...   Oct 22 2019, 04:12 PM
Rand   "Dr 914" is here to sell you parts. You ...   Oct 22 2019, 04:16 PM
surfdogskier   "Dr 914" is here to sell you parts. You...   Oct 22 2019, 07:03 PM
Rand   I still want an explanation to why MPS was even br...   Oct 22 2019, 04:26 PM
surfdogskier   I still want an explanation to why MPS was even b...   Oct 22 2019, 04:48 PM
rhodyguy   Yes. No pump power right now.   Oct 22 2019, 04:33 PM
surfdogskier   Ok, I connected the 4 pin to the ground as mention...   Oct 22 2019, 04:53 PM
bbrock   Did you set the float levels on both carbs when yo...   Oct 22 2019, 05:58 PM
rhodyguy   Model of distributor? Go through the setup procedu...   Oct 22 2019, 06:56 PM
surfdogskier   Model of distributor? Go through the setup proced...   Oct 22 2019, 07:09 PM
surfdogskier   I am now thinking my timing is off. I am getting...   Oct 22 2019, 07:11 PM
thelogo   Carbs are king :poke:   Oct 22 2019, 07:50 PM
sixnotfour   180 out   Oct 22 2019, 08:12 PM
GregAmy   Post how you have it wired?   Oct 22 2019, 09:01 PM
surfdogskier   Post how you have it wired? I have it wired the ...   Oct 23 2019, 07:50 AM
GregAmy   Post how you have it wired? I have it wired the...   Oct 23 2019, 08:35 AM
surfdogskier   [quote name='surfdogskier' post='2756654' date='O...   Oct 23 2019, 08:52 AM
GregAmy   Edited noon for errors. I know. I did the SirAnd...   Oct 23 2019, 09:40 AM
rhodyguy   The Dansk from pelican is the quivelent of a 009? ...   Oct 23 2019, 07:15 AM
surfdogskier   The Dansk from pelican is the quivelent of a 009?...   Oct 23 2019, 07:49 AM
rhodyguy   No. 1, 4, 3, 2. Review chapter 3 of your Haynes.   Oct 23 2019, 08:11 AM
surfdogskier   No. 1, 4, 3, 2. Review chapter 3 of your Haynes. ...   Oct 23 2019, 08:53 AM
sixnotfour   go by the picture   Oct 23 2019, 09:48 AM
GregAmy   go by the picture With key on and pump runnin...   Oct 23 2019, 10:02 AM
surfdogskier   go by the picture With key on and pump runni...   Oct 23 2019, 11:32 AM
GregAmy   Fuel pump relay pulled, pump goes off. Power supp...   Oct 23 2019, 11:39 AM
Gatornapper   #1 - you need this jumper on your relay board (low...   Oct 23 2019, 10:12 AM
surfdogskier   #1 - you need this jumper on your relay board (lo...   Oct 23 2019, 06:11 PM
Literati914   "Dr 914" is here to sell you parts. Yo...   Oct 23 2019, 01:11 PM
surfdogskier   I will work on the fuel pump not shutting off afte...   Oct 23 2019, 01:35 PM
rhodyguy   Figure out where TDC on cyl #1 is. Use the engine ...   Oct 23 2019, 02:08 PM
surfdogskier   Figure out where TDC on cyl #1 is. Use the engine...   Oct 23 2019, 02:58 PM
sixnotfour   the ground needs to be #3 not #4 as before mentio...   Oct 23 2019, 02:22 PM
sixnotfour   the ground needs to be #3 not #4 as before menti...   Oct 23 2019, 06:48 PM
injunmort   sounds like you need to static time engine from th...   Oct 23 2019, 03:18 PM
IronHillRestorations   Did you turn your engine over to TDC#1 before you ...   Oct 23 2019, 04:10 PM
surfdogskier   Did you turn your engine over to TDC#1 before you...   Oct 23 2019, 04:57 PM
surfdogskier   Did you turn your engine over to TDC#1 before you...   Oct 23 2019, 04:58 PM
surfdogskier   I found the TDC on my fan. Saw where my rotor but...   Oct 23 2019, 06:08 PM
dlee6204   I found the TDC on my fan. Saw where my rotor bu...   Oct 23 2019, 06:24 PM
surfdogskier   I found the TDC on my fan. Saw where my rotor b...   Oct 23 2019, 07:33 PM
rhodyguy   Where on the cap did #1 wind up? Normally it would...   Oct 23 2019, 07:21 PM
surfdogskier   Where on the cap did #1 wind up? Normally it woul...   Oct 23 2019, 08:38 PM
- Lo-Fi Version Time is now: 26th April 2025 - 09:00 PM
