> Rebel Racing Coil Overs
Biggles
post Oct 23 2019, 11:37 AM
Region Association: England
I’ve bought a set of rebel racing adjustable perches to go over my rear bilstein dampers.
Unfortunately, for the duel rate springs I have (tender and main spring), the isolator collar (between the two springs) ID at 54mm is just too small to go over the OD of the threaded tube, meaning I have to go up in spring size to 60mm ID I think
Question: what ID springs do people use with this Rebel Racing set up and do you find the springs rub on the threaded tube ?
See below
Thanks, Chris
wysri9
post Oct 24 2019, 02:16 PM
I am about to install the Rebel Racing Coilovers with 150lb Eibach springs. No helper springs though - can somebody explain the benefit of the helper springs?? Am I missing a trick here?
Thanks
Simon
- Lo-Fi Version Time is now: 31st October 2024 - 09:33 PM
