> right light does not come up revisited bought multi meter, 1974 914 1.8
brcacti
post Oct 24 2019, 03:12 PM
Hello, I bought a multimeter to check the current to the headlight, current was fine then I moved the gray wire, was very cramped and it broke off. I turned on the headlights and touched the broken wires together and the light DID COME UP. .........BUT............ how do I connect the very tiny wires together? what kind of electrical connection to use or solder it together?Attached Image Attached Image
lierofox
post Oct 24 2019, 08:09 PM
That's a diode and it's broken off at the body of the diode itself. You'd have a difficult time resoldering that back together like that, but if there's anywhere nearby that sells electronic components you can probably get away with buying a "1N4001" diode to solder in its place, they're DIRT CHEAP if you buy them in bulk, but you shouldn't pay more than a few bucks for a 5 pack at the most expensive.
If you do decide to solder a replacement in, they ARE directional, so make sure the white stripe faces the proper direction, in this case the white stripe goes on the opposite end of the wire.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-18880-1571969340.1.png)
Edit: What year is yours anyway? I just checked the motor on my '75 and the diodes are inset into a small plastic clip to hold them safely in place... oh it's in the topic title, '74. I can read.
brcacti
post Oct 25 2019, 03:47 PM
QUOTE(lierofox @ Oct 24 2019, 07:09 PM) *
Thanks I will try soldering the old diode first, if it does not work then will buy new one probably online, THANKS FOR YOUR HELP
lierofox
post Oct 25 2019, 03:58 PM
QUOTE(brcacti @ Oct 25 2019, 02:47 PM) *
With how it's broken off, it may be unable to be repaired without replacement, don't feel disappointed if it won't bond with solder. Best of luck though!
- Lo-Fi Version Time is now: 31st October 2024 - 10:25 PM
