Fuel pump just quit |
surfdogskier |
Oct 26 2019, 11:51 AM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
So I had everything working well on my carb conversion with the exception of the fuel pump which constantly ran unless I pulled the ground wire per SirAndys carb conversion write up.
Now my pump will not work at all. I direct wired it to the battery to see if the pump was good and it worked. I connected a 12 volt wire to my relay board at the black/red wire #13 connection and it worked. So no issue with the wire. However something on the relay board or relay prevents it from working when the key is turned on. I was going to wire it to the 2 other points on the relay board to get 12 volts (T4b and the #12 pin on the T12 connector). However, with the key turned on, I am not getting 12 volts to either of these. the T4b, I am getting 2 volts and the pin 12 on the T12 I am getting 4 volts. My only other option to get 12 volt power is to connect to my coil but I have read this is not a good idea. Looking for some guidance. Attached image(s) |
porschetub |
Oct 26 2019, 03:22 PM
Advanced Member Group: Members Posts: 4,754 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Did you check the pump and power supply relays,reason I ask is I had this issue the pump relay went south,fixed that and then the supply relay did the same..old parts,lucky I have heaps of spare relays (IMG:style_emoticons/default/dry.gif) .
Lo-Fi Version | Time is now: 26th December 2024 - 06:17 PM |
