> Fuel pump just quit
surfdogskier
post Oct 26 2019, 11:51 AM
So I had everything working well on my carb conversion with the exception of the fuel pump which constantly ran unless I pulled the ground wire per SirAndys carb conversion write up.
Now my pump will not work at all. I direct wired it to the battery to see if the pump was good and it worked. I connected a 12 volt wire to my relay board at the black/red wire #13 connection and it worked. So no issue with the wire. However something on the relay board or relay prevents it from working when the key is turned on.
I was going to wire it to the 2 other points on the relay board to get 12 volts (T4b and the #12 pin on the T12 connector). However, with the key turned on, I am not getting 12 volts to either of these. the T4b, I am getting 2 volts and the pin 12 on the T12 I am getting 4 volts.
My only other option to get 12 volt power is to connect to my coil but I have read this is not a good idea.
Looking for some guidance.
injunmort
post Oct 26 2019, 03:36 PM
I would suggest getting rid all jumpers, grounds and any other added wiring and run a fused wire from the last resort position in your first post to the pump. if the pump works when switched on with key, your wiring was suspect, if it does not, you have an issue with relay board or before it. I have been running this way for years without issue. the wiring for the pump is simple, switched 12v to + side of pump. - side goes to a chassis ground.
surfdogskier   Fuel pump just quit   Oct 26 2019, 11:51 AM
rhodyguy   With the key in the on position, do you have 12v a...   Oct 26 2019, 12:03 PM
surfdogskier   With the key in the on position, do you have 12v ...   Oct 26 2019, 12:31 PM
lierofox   So I had everything working well on my carb conve...   Oct 26 2019, 12:32 PM
surfdogskier   So I had everything working well on my carb conv...   Oct 26 2019, 12:33 PM
surfdogskier   I am not seeing any blown fuses under the dash or ...   Oct 26 2019, 12:44 PM
rhodyguy   the last sentence has me confused. The stand alone...   Oct 26 2019, 12:57 PM
surfdogskier   the last sentence has me confused. The stand alon...   Oct 26 2019, 01:03 PM
lierofox   [quote name='rhodyguy' post='2757415' date='Oct 2...   Oct 26 2019, 02:33 PM
surfdogskier   [quote name='rhodyguy' post='2757415' date='Oct ...   Oct 26 2019, 04:57 PM
lierofox   Thanks for this image and info. I haven't se...   Oct 26 2019, 05:18 PM
Minerva's 914   RE: Fuel pump just quit   Oct 26 2019, 01:11 PM
Superhawk996   :rotfl: Well done!   Oct 26 2019, 04:17 PM
rhodyguy   with the extra wire for power and the jumper groun...   Oct 26 2019, 01:46 PM
surfdogskier   with the extra wire for power and the jumper grou...   Oct 26 2019, 02:14 PM
porschetub   Did you check the pump and power supply relays,rea...   Oct 26 2019, 03:22 PM
rhodyguy   Are you sure the relay is good? Plug it in to a re...   Oct 26 2019, 03:26 PM
injunmort   I would suggest getting rid all jumpers, grounds a...   Oct 26 2019, 03:36 PM
surfdogskier   I swapped the relays around but there was no diffe...   Oct 26 2019, 04:00 PM
lierofox   I swapped the relays around but there was no diff...   Oct 26 2019, 04:38 PM
porschetub   I swapped the relays around but there was no dif...   Oct 26 2019, 11:40 PM
surfdogskier   She now purrs like a kitten. Thank all of you fo...   Oct 27 2019, 06:07 AM
KELTY360   She now purrs like a kitten. Thank all of you f...   Oct 27 2019, 02:34 PM
surfdogskier   She now purrs like a kitten. Thank all of you ...   Oct 27 2019, 06:42 PM
lierofox   The biggest point of caution I'd give for that...   Oct 28 2019, 01:17 PM
surfdogskier   The biggest point of caution I'd give for tha...   Oct 28 2019, 01:55 PM
914_teener   :thumbsup: :brain: :blowup:   Oct 28 2019, 01:46 PM
rhodyguy   :blink:   Oct 28 2019, 01:55 PM
Rand   I understand the hack to get by. I do that too. Bu...   Oct 28 2019, 04:09 PM
lierofox   I understand the hack to get by. I do that too. B...   Oct 28 2019, 06:30 PM
- Lo-Fi Version Time is now: 26th December 2024 - 05:24 PM
